mean60impalagene
Reg: 01-31-13
11-10-23 06:48 AM - Post#2864034
I would like to know the correct set up on a short shaft turbo 350 going behind a 250 4.1 engine 4 barrel carb. dual exhaust... as in flex plate, torque converter. T.I.A.
11-12-23 09:40 AM - Post#2864080
In response to mean60impalagene
can you give more details on what you are running, intended use, and whatnot?
mean60impalagene
Reg: 01-31-13
11-12-23 10:25 AM - Post#2864088
In response to bobb
73 Chevy machined 4.1 250 in a 1960 Chevy Impala. 4 barrel carb. dual exhaust, Auto 350 turbo with stock 6 cylinder rear end. Just a weekend cruiser no racing. Need info on flex plate, torque converter and any other tips. T.I.A.
Edited by mean60impalagene on 11-12-23 10:29 AM. Reason for edit: No reason given.
11-12-23 07:15 PM - Post#2864115
i would lean towards a torque convertor with 2000 rpm stall so you can get going from a standing start. 153 tooth flexplate and starter to match. hope you have a small carb like a 390.
mean60impalagene
Reg: 01-31-13
11-14-23 04:53 PM - Post#2864175
In response to bobb
Thank you and now I have a better idea on which way to go... again thanks bobb
Edited by mean60impalagene on 11-14-23 04:55 PM. Reason for edit: No reason given.
