Denver56BelAir
Loc: Parker, Colorado
Reg: 01-11-05
10-07-23 09:26 AM - Post#2863166
I have a 56 BelAir. I want to improve the steering so it’s not so hard. It’s stock now with a stock front end.
I think rack and pinion might be too much for me to tackle.
I’ve heard a method where the gear box can get changed to a different ratio.
My goal is to replace the stock steering wheel with a 15” diameter
Paul
Parker, Colorado
56 BelAir Post, T56, 327, 4:11, Astro custom chrome steel wheels,
10-07-23 10:15 AM - Post#2863167
In response to Denver56BelAir
First a smaller wheel will increase steering effort, without p/s. You can retrofit a firm feel different ratio steering box, available from several companies. Or retrofit a power assist system.
Edited by Shepherd on 10-07-23 10:16 AM. Reason for edit: No reason given.
Denver56BelAir
Reg: 01-11-05
10-07-23 04:13 PM - Post#2863170
Tell me about power assist and and the gearbox option?
I don’t want to add a power steering pump
Paul
Parker, Colorado
10-07-23 04:27 PM - Post#2863171
Well no p/s then. Here's one of many examples available. https://www.amazon.com/16-Steering-Tri-Five- BuyAut...
10-08-23 10:49 AM - Post#2863181
quicker ratio will have a better feel but harder to turn. espesialy parking. maybe electric?
Denver56BelAir
Reg: 01-11-05
10-08-23 04:58 PM - Post#2863188
In response to bobb
Maybe electric assist is the way to go. It works well on my 2016 Arctic Cat UTV
Paul
Parker, Colorado
Denver56BelAir
Reg: 01-11-05
10-08-23 05:01 PM - Post#2863189
I found this electric conversion. I’m not sure if this is the power assist referenced in the thread.
https://www.classicchevy.com/epas-performance-elec ...
Paul
Parker, Colorado
10-08-23 05:02 PM - Post#2863190
You will need an alternator with 80-100 amp out put, depending on what other components you have in the car.
Edited by Shepherd on 10-09-23 04:31 AM. Reason for edit: No reason given.
Coley
Loc: Milledgeville, IL. 61051
Reg: 11-23-00
10-08-23 06:45 PM - Post#2863192
I would suggest that you find out what sort of guarantee goes with a system like this. The Chevy HHR and others are using an ESP system, but they be real nightmare to repair problems with them.
Any man that thinks he is too old to learn new things, probably always was.... |
5Larry7
"20th Year" Gold Supporting Member
Loc: Dallas, TX
Reg: 05-17-04
10-09-23 09:18 AM - Post#2863211
The electric power steering systems I have looked at so not change the ratio only provide assist. I would want a quicker ratio with power assist.
'96 Replica of a 1950's Teardrop Trailer. |
10-09-23 11:50 AM - Post#2863213
In response to 5Larry7
There are several quick ratio boxes, the aftermarket electric pump can mate to these. Without assist they require more steering effort though.
Denver56BelAir
Reg: 01-11-05
10-10-23 03:18 PM - Post#2863253
I located a power steering box that will work with a stock steering column without modifications to the column. Too bad this website won’t let me upload a picture from my iPhone 13.
If I go the route of a pump, can someone send me a link to a pump with a reservoir? I have a 327 small block in my car. I’ll need to find a bracket too
Paul
Parker, Colorado
Member #409
10-10-23 04:05 PM - Post#2863254
You have bad information. No way a stock steering column works unless you modify it by shortening it.
