Username Post: 1954 235 engine ticking sound        (Topic#373861)
Larry E
Larry E
Loc: Los Angeles
Reg: 09-15-16
10-06-23 06:40 AM - Post#2863127
Anyone have any suggestions on what might be causing my 1954 235 (in a 1950 styleline) to have a ticking sound coming from the timing chain area?
I thought it was the water pump but yesterday I got a pvc pipe (no stethoscope available) and placed it in different spots around where I thought the ticking sound was coming from. Engine was rebuilt less than a 1,000 miles ago. Changed the oil back in march.
1950 Chevy Styleline Deluxe 235
Larry E
Larry E
Loc: Los Angeles
Reg: 09-15-16
10-06-23 07:11 AM - Post#2863129
    In response to Larry E
By the way,
I'm using Valvoline Racing oil VR1 20w-50
drtyler
Loc: Georgia
Reg: 05-06-10
10-06-23 07:27 AM - Post#2863131
Is there any way that you could post a video of the sound?
No timing chain. The cam and crank each have gears which mesh together. The original cam gear on cars was fiber. Trucks used aluminum. The aluminum gear is interchangeable with fiber gear.
Larry E
Larry E
Loc: Los Angeles
Reg: 09-15-16
10-06-23 07:36 AM - Post#2863132
    In response to drtyler
I will get a recording of it this evening or tomorrow morning. Thanks
Tlentz
Loc: Litchfield Park
Reg: 06-19-14
10-10-23 01:11 PM - Post#2863246
Hydraulic lifters? Ticks are common knocks are not. Is it a consistent tick or knock or is it intermittent?
Hurry up and wait...and don't use RAMCO
Tlentz
Reg: 06-19-14
10-10-23 01:13 PM - Post#2863248
    In response to Tlentz
I had a 41 Cadillac that would start ticking, it was a lifter. The fix was a heavier weight oil or additive.
Larry E
Larry E
Loc: Los Angeles
Reg: 09-15-16
10-24-23 08:05 AM - Post#2863568
So I removed 1 quart of oil and added 1 quart of Lucas Heavy Duty oil stabilizer hoping it would help. No Luck. Still making the ticking sound up front behind the main pulley. I dont see an option to upload video with sound
Larry E
Larry E
Loc: Los Angeles
Reg: 09-15-16
10-24-23 08:12 AM - Post#2863570
Attachment: engine_number.jpg (31.09 KB) 4 View(s)
Her is my engine number
Larry E
Larry E
Loc: Los Angeles
Reg: 09-15-16
10-24-23 08:28 AM - Post#2863571
Attachment: sound.mp4 (1.5 MB) 43 View(s)
Member #189 Moderator and "21th Year" Platinum Supporting Member
10-24-23 11:25 AM - Post#2863573
I am no expert, but that sounds like a rocker arm hitting something besides the valve. Have you pulled the rocker arm cover and looked at the rocker arms?
29-41, 42-48, 49-54 Moderator
1nice52
1nice52
Loc: Navarre FL, USA
Reg: 11-13-03
10-24-23 12:23 PM - Post#2863576
Take the belt off and see if it still ticks.
RON
"52" Styleline Deluxe (In the family since new)
"53" Bel Air (Bucket list in progress)
Larry E
Larry E
Loc: Los Angeles
Reg: 09-15-16
10-24-23 12:42 PM - Post#2863578
    In response to 1nice52
Initially I thought it was my water pump also. But when I use a pvc pipe or rubber hose as a stethoscope the noise seems to be coming from the cover behind the main pulley. I tried listing to the valve cover, water pump, fuel pump and cover behind the main pulley. That was the only place I could hear the ticking.
Larry E
Larry E
Loc: Los Angeles
Reg: 09-15-16
10-24-23 12:43 PM - Post#2863579
But for the heck of it I will take off the belt and try again tonight. You never know.
10-24-23 12:57 PM - Post#2863580
I don't think that is a valve train noise, to be sure the valve cover should come off as suggested. Possible timing gear noise is on the table.
10-24-23 08:45 PM - Post#2863585
I know you are a mechanic with a lot of experience. Weren't the original timing gears fiber?
10-25-23 04:33 AM - Post#2863594
Pretty sure they were fiber, but by now they may have been replaced.
Edited by Shepherd on 10-25-23 04:33 AM. Reason for edit: No reason given.
soxfan
Loc: West Lafayette, IN
Reg: 03-05-16
10-25-23 06:01 AM - Post#2863599
Is it possible that one of the fan blades is slightly bent and hitting the radiator.
Larry E
Larry E
Loc: Los Angeles
Reg: 09-15-16
11-06-23 10:15 AM - Post#2863895
    In response to soxfan
So I found out where the clanking noise is coming from. Looks like the rivets that attach the fan belt pulley to the harmonic balancer are loose.
I might have found a friend with a extra harmonic balancer. Will find out later today. Doesn't look like anyone makes new ones so hopefully is is in good shape.
1nice52
1nice52
Reg: 11-13-03
11-06-23 10:52 AM - Post#2863898
https://www.damperdoctor.com/
RON
Larry E
Larry E
Loc: Los Angeles
Reg: 09-15-16
11-06-23 12:31 PM - Post#2863902
Thanks Ron,
I can't believe how expensive they are now.
$500 plus $100 core
Larry E
Larry E
Loc: Los Angeles
Reg: 09-15-16
11-13-23 10:22 AM - Post#2864134
Can someone confirm that a 1954 235 engine Harmonic Balancer would have come with a pulley for thin 3/8" or thick 5/8" fan belt. Thank you
greenock
Reg: 11-10-09
11-13-23 12:24 PM - Post#2864136
The 54 should have the narrow belt, 53 was the first narrow belt, probably because the power steering equipped cars had a double grove harmonic balancer.
1932 Special Sedan
1952 Bel Air powerglide
1958 Impala Convertible
Greenock- circa 1854 - New Zealand's oldest American house.
Greenock Garden, Karaka, Auckland.
Larry E
Larry E
Loc: Los Angeles
Reg: 09-15-16
11-13-23 01:22 PM - Post#2864138
    In response to greenock
That's strange because my engine is a 1954 235 and it has a wide belt. Maybe someone changed it in the past.
eplantage
Loc: Southern MN
Reg: 03-15-04
11-13-23 01:44 PM - Post#2864139
I've got a 235 from a '54 ready for my '53 and it has the narrow pulley.
Age: 69 at the moment
1950 Chevrolet Sedan Delivery
2002 Heritage Springer FLSTSI
1930 Model A Standard Coupe
11-14-23 05:09 AM - Post#2864153
    In response to eplantage
Over the years owners and their mechanics made many unorthodox changes to keep our old cars on the road.
Larry E
Larry E
Loc: Los Angeles
Reg: 09-15-16
11-20-23 02:29 PM - Post#2864302
So will it be ok if I replace my harmonic balancer with this other one? I've cleaned it up an getting ready for a mechanic to install next week. You can see they have differences.
Sending pics next
Larry E
Larry E
Loc: Los Angeles
Reg: 09-15-16
11-20-23 02:41 PM - Post#2864303
Larry E
Larry E
Loc: Los Angeles
Reg: 09-15-16
11-20-23 02:44 PM - Post#2864305
Attachment: mine.jpg (118.18 KB) 2 View(s)
Attachment: a.jpg (206.57 KB) 0 View(s)
Attachment: b.jpg (195.53 KB) 0 View(s)
Attachment: c.jpg (182.31 KB) 0 View(s)
Larry E
Larry E
Loc: Los Angeles
Reg: 09-15-16
11-20-23 02:48 PM - Post#2864306
The reason I want to use this one is because all the others I have come across have a thin belt pulley were mine has a thick 5/8" belt. Which matches my water pump and alternator.
Execution time: 0.162 seconds.   Total Queries: 20   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:15 AM
