Username Post: stored Camaro        (Topic#373773)
J C
Loc: Orange Co. Calif
Reg: 04-17-04
09-16-23 03:01 PM - Post#2862597
This car has sat for at least 2 yrs. After pulling the plugs what is the best fluid to put into the cylinders to help when restart. Also after putting in the fluid should I replace the plugs and start it or turn it over without the plugs then put the plugs in and restart the car.
69RSZ28 71 Chevelle 79 Silverado 24K mi.
10-08-23 10:56 AM - Post#2863182
    In response to J C
sorry nobody responded. i would use a liberal amount of wd40 and turn it by hand with no plugs and valve covers off to make sure all the valves work correctly. put in new oil and filter. crank with starter without plugs to get oil to the top end. compression test and then fire up.
J C
Reg: 04-17-04
10-10-23 06:45 PM - Post#2863257
    In response to bobb
bobb. Thanks for the help. Doesn't sound like you leave anything to chance. Better safe than sorry. Thanks again. She still is waiting.
elcamino
elcamino
Reg: 03-30-00
11-07-23 09:28 AM - Post#2863935
    In response to J C
I would never use WD40 in the cylinders.
2021 GMC 4WD Sierra Denali Ultimate 6.2L/10-sp
2022 Polaris RZR XP 1000 Ride Command
2017 John Deere X738
J C
Reg: 04-17-04
11-08-23 07:23 PM - Post#2863990
    In response to elcamino
Mike. Why not besides its kinda thin.What would you use?
Edited by J C on 11-08-23 07:24 PM. Reason for edit: No reason given.
Execution time: 0.138 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:54 AM
