Username Post: Truckstell O/D manual?        (Topic#373761)
52Blackbetty
Reg: 03-13-23
09-12-23 09:06 AM - Post#2862499
Does anyone know of anyone that has a copy of a 103 model manual? I would even be willing to pay for a digital scanned copy
I just picked up one along with the torque tube and 3rd member it was installed with just want to have and know all of the ins and outs thanks in advance
Evan
52 Chevy styleline special sport coupe
“Black Betty”
46 ford one ton flat 6
“Wilbur”
Tractors
20+ hit and miss engines
I’m only 35 but grew up around old iron
Member #189 Moderator and "21th Year" Platinum Supporting Member
09-12-23 02:18 PM - Post#2862504
    In response to 52Blackbetty
Welcome to ChevyTalk. rrauch has or had one. Hopefully he will see your post. If you search truckstell, there are a lot of posts about them. Seen some names of guys that have passed and some that have not been on here for some time.
29-41, 42-48, 49-54 Moderator
52Blackbetty
Reg: 03-13-23
09-12-23 02:22 PM - Post#2862505
Thanks yeah I’ve been through a lot of the posts and they are fairly old I have seen a lot of him in posts and sent him a message
Evan
“Black Betty”
“Wilbur”
Tractors
09-13-23 07:14 PM - Post#2862555
I have a Truckstell unit. I won't be using it, as it won't fit the X-frame in my convertible. I have a lot of paper manual stuff about them.
Do you have the push/pull knob that attaches under the dash?
What do you need to know?
09-14-23 06:28 AM - Post#2862564
BlackBetty, I don't remember getting a message from you. Please re-send.
52Blackbetty
Reg: 03-13-23
09-14-23 09:00 AM - Post#2862566
Yes I have all cables even dash cable and speedo cable with the modified torque tube. Just didn’t know if there was an actual installation manual or one that maybe talks about adjustments. Literature would be awesome would you be willing to make copies?
One thing I’d like to know if there is instructions on cutting the floor something I red said that the kit maybe came with a patch panel for after you cut the floor I just lowered mine 3” so it will have to be trimmed more probably. I’m a 35yr old mechanic I think I have it mainly figured out . Thanks for any info
Evan
“Black Betty”
“Wilbur”
Tractors
09-14-23 12:13 PM - Post#2862571
I'll check my literature, but I don't remember an installation manual. Are you going to run yours with the sprag clutch? Or try to use it as a sort of in-out OD?
52Blackbetty
Reg: 03-13-23
09-18-23 07:55 PM - Post#2862655
I plan on running it like intended with clutch cable does the fron of the overdrive input go into the ball on the trans if so I have an extra flange coupling with the clamp bolts
Evan
“Black Betty”
“Wilbur”
Tractors
09-19-23 02:33 PM - Post#2862682
Take a look at this.
52Blackbetty
Reg: 03-13-23
09-21-23 10:15 AM - Post#2862715
Ok thanks that makes more sense the ball part from the trans works a “slip yoke” over the outer part of OD input so I have an extra rear flange clamp I guess
Evan
“Black Betty”
“Wilbur”
Tractors
Execution time: 1.381 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:01 PM
