Username Post: remove inside door panel        (Topic#373619)
GENO99100
Loc: Port Charlotte, Fl.
Reg: 04-23-22
08-14-23 09:15 AM - Post#2861519
How do I remove inside front door inside panel on my 1955 chevy belair 2dr. sedan?
Edited by Tony on 08-14-23 10:33 AM. Reason for edit: Moved to correct 55-57 forum.
Bad56Sedan
Bad56Sedan
Reg: 04-29-04
08-14-23 04:13 PM - Post#2861539
    In response to GENO99100
Welcome to Chevy Talk,
You asking in the original forum,
So I’m guessing your door panel is attached in the original manner.
Several items need to be removed,
Inside window garnish molding
Inside door handles
Screws for arm rest
Once these items are removed, using an upholstery tool you can get between the door panel and the metal door you slide it to each attachment nail and back it out of the door,
Once that’s done lift the door panel up and unhook it from the door, there is a metal retaining strip on the panel and the door at the bottom.
For those that may be wondering, the hooptijutillater does not have to be removed.
VC56S 2 door Sedan, 43 Years
Edited by Bad56Sedan on 08-14-23 04:14 PM. Reason for edit: No reason given.
GENO99100
Reg: 04-23-22
08-15-23 12:21 PM - Post#2861568
    In response to Bad56Sedan
Thanks, I have looked at a few pics and trying to find service manual or video of the removal of door panel so I don't bend or brake anything. Thanks again for answering my post. Geno
GENO99100
Reg: 04-23-22
08-15-23 12:33 PM - Post#2861570
There isn't any pics or video of removing front door panel is there as I haven't found any yet? Geno
Bad56Sedan
Bad56Sedan
Reg: 04-29-04
08-15-23 03:51 PM - Post#2861579
I looked at some info I had the 1956 assembly manual, the 1956 Shop manual and the 1955 interior Trim online but didn't find anything about removing the door panel.
Reading through the 1956 shop manual section "Body Section 1-8" there is a reference to
"Servicing the front doors is covered in the 1955 Shop Manual"
naturally I don't have the 1955 manual
GENO99100
Reg: 04-23-22
08-24-23 09:59 AM - Post#2861882
Where can I look at a shop manual for the 55 cheve 2dr. sedan? Geno
Execution time: 0.156 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:40 PM
