Username Post: Transmission fluid change        (Topic#373611)
bolake
Loc: Northern MN
Reg: 09-05-17
08-13-23 07:56 AM - Post#2861470
Could find on a search. In process of buying a 2011 Camaro 2SS 6.2 automatic with 16333 miles, Carfax show one owner. Wondering if it would be good to have tranny serviced, just fluid change or flush to?
If your not the lead dog the view never changes
elcamino
Member #185
elcamino
Reg: 03-30-00
12-29-23 04:23 AM - Post#2865361
    In response to bolake
I would. Contrary to popular opinion, ATF does not last forever. OEM fluids come from the low bid supplier. While they meet GM spec (at the time) it does not mean they are the best.
Here is what I use in my 2021 Sierra Denali 6.2L/10-speed>>>100% Synthetic ATF
Note--Changing ATF on these cars is not a simple do-it-yourself project, there are no dipstick so professional service is recommended. There is a YouTube video on this subject.
value="transparent">
2024 GMC 4WD Sierra Denali 3.0L/10-sp
2022 Polaris RZR XP 1000 Ride Command
2017 John Deere X738
Edited by elcamino on 12-29-23 04:31 AM. Reason for edit: No reason given.
01-28-24 10:04 AM - Post#2866375
    In response to elcamino
personaly i would drop the pan, add a plug, replace the filter and change the fluid. future fluid changes, every other oil change or so, would just be drain and fill. the filter is most likely just a screen. draining might get half the fluid out. a flush would get costly and you would need to make an apointment and all the hassle that goes with that. plus the upsell bs. i would also get a spare fill plug, just in case. it may seem to much for lots of people but thats what i would do for a car i intend to keep... plus more. lol
blang88
Reg: 01-29-24
02-01-24 10:18 AM - Post#2866479
Did I read that right 2011 with 16k miles. Somebody's been babying it, you prob have nothing to worry about.
Chevy Silverado 1500 (Mine)
2025 Chevy Equinox (Wife's)
xstuntman
Loc: west Texas
Reg: 04-13-09
10-18-24 04:42 PM - Post#2874818
    In response to blang88
Mine is at 16,525 and babied. It's surprising how many are garage queens.😁
Yeah, at 16k not much reason to change unless you just want piece of mind. They don't come with dipstick tubes but you can add them (yeah, stupid GM). I would agree on the pan drop and adding a drain plug too.
I would suggest doing a radiator flush tho since GM recommends 5 years or 50k iirc.
I swapped out the diff fluid to and glad I did.
10-19-24 09:53 AM - Post#2874837
    In response to xstuntman
in my mind the first fluid change is the most important. everything is broke in and the chips, chafe, crumbs, and leftovers sitting at the bottom gets removed.
Execution time: 1.208 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:38 PM
