Username Post: sbc built        (Topic#373605)
ernest65
Reg: 08-11-23
08-12-23 08:47 AM - Post#2861401
I am building a sbc 350 with roller lifters and had a couple of questions if anybody can help please.
1. I will be purchasing a top end kit that does not include the lifter rods. how do you determine the right size rods?
2. Where can i purchase affordable roller lifters without breaking the bank.
3. The heads that i am looking at are 190cc heads so is this the right cam for it below if not what cam do you recommend.
I want .490-515 Lift and 110-112 LSA.
Any advice you can provide would be a great help.
Edited by Tony on 08-12-23 05:49 PM. Reason for edit: Moved to performance forum
Tony1963
BANNED USER
Loc: Orlando Florida
Reg: 07-09-18
08-12-23 06:04 PM - Post#2861435
    In response to ernest65
Years ago we used a company called Northern Auto Parts and they were absolute experts on engine rebuild parts.
https://www.northernautoparts.com/
rumrumm
"22nd Year" Silver Supporting Member
rumrumm
Loc: Macomb, IL
Reg: 10-18-01
08-13-23 07:07 AM - Post#2861459
Need more information. Everything choice depends on what combination of parts you have. What pistons are you using? What is the combustion chamber size of the heads you are referencing? Has your block been decked? What is the duration @ .050 of the cam you mentioned and what brand is it?
Lynn
"There's no 12-step program for stupid."
383 sbc, Eagle, AFR, SRP, CompCams, FiTech Fuel Injection, Dyno #'s: 450 hp @ 5700, 468 lb. ft. of torque @ 4300.
Edited by rumrumm on 08-13-23 07:09 AM. Reason for edit: No reason given.
08-13-23 12:10 PM - Post#2861475
how heavy is the vehicle? auto - stick? intended use? rear gear? please do not buy parts till you have a definite list.
08-19-23 10:26 AM - Post#2861712
what compression ratio or type of piston do you have?
Execution time: 0.435 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:10 PM
