Username Post: Intake manifold        (Topic#373454)
Paul66
Loc: Southern Ontario
Reg: 08-24-18
07-15-23 11:43 AM - Post#2860325
Can a 283 intake with just 2 front water ports be mated to heads with both front and rear ports
Member #409
07-16-23 11:48 AM - Post#2860353
    In response to Paul66
They are all that way.
07-16-23 12:01 PM - Post#2860355
bolt pattern must be the same.
grumpyvette
grumpyvette
Loc: farmersville texas USA
Reg: 03-16-01
07-16-23 04:02 PM - Post#2860365
    In response to bobb
yeah, since the heads are interchangeable, too either side of the block,they can be used on left or right bank, the rear coolant port in the heads is blocked by the non-existent rear manifold coolant passage on most intakes while in use
coolant flows up into the cylinder heads from the block and flows forward through the heads back to the t-stat/radiator
https://garage.grumpysperformance.com/index.php?th...
Edited by grumpyvette on 07-16-23 04:09 PM. Reason for edit: No reason given.
Execution time: 0.145 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:41 AM
