Username Post: 230 engine need motor mounts        (Topic#373373)
asahi1234
Reg: 06-19-14
07-01-23 11:30 AM - Post#2859825
I have a 39 Chevrolet master deluxe it orginally had a 216 engine in it. I am going to but a 230 engine in it. Where can I find motor mounts? If some companies that makes any? Thanks.
Tony1963
BANNED USER
Loc: Orlando Florida
Reg: 07-09-18
07-01-23 01:27 PM - Post#2859830
    In response to asahi1234
Just out of curiosity, I checked the Rock Auto site and found none.
None on eBay either.
Do you have a pic of the old one?
asahi1234
Reg: 06-19-14
07-01-23 07:16 PM - Post#2859841
    In response to Tony1963
The orginal motor mounts supports location front of the motor below the water pump. And the other ones location was towards the front of the trans. The 230 engine motor mounts location are in the middle of the engine. On the side of the engine block just above the oil pan.
Edited by asahi1234 on 07-01-23 07:20 PM. Reason for edit: No reason given.
Tony1963
BANNED USER
Reg: 07-09-18
07-02-23 05:11 AM - Post#2859844
If you have the old mounts, you might try to buy some bulk motor mount material and see if that will bond to the original steel frame.
I seem to recall reading somewhere an article where this was one. They used a band saw to cut the material and also add the cutout where the motor mount fit in place. They used some type of body shop panel adhesive to bond them together.
Mike Boteler
Loc: Maryland
Reg: 09-11-17
07-14-23 10:08 AM - Post#2860305
What trans/bellhousing are you going to use? The 230 has side motor mounts while the 216 used a front mount and the side of the bellhousing.
More info on what you're trying to do (the big picture) will help get the right answer...
Mike B
1971BB427
Loc: Portland,Or
Reg: 12-06-09
07-15-23 06:08 AM - Post#2860320
    In response to Mike Boteler
I think the adapter mounts to put a V8 in your car could be easier to use to swap the 230 into your car, and take less reworking than anything else. But if I was doing this swap I'd simply bolt on original 230 motor mounts, and position the engine in the car, and fabricate the mounts from steel plate.
But you've got a lot more than motor mounts to build in order to make this engine swap complete. Since you will need a different bellhousing, and likely may end up needing to swap out trans, rear axle, and go to open driveline.
Best to ferret out the whole swap before you start the engine part.
1969 Suburban 2wd 350
1939 Chevy pass. coupe 350/700R4
1937 Austin gasser 327/TH350
51chevcoupe
51chevcoupe
Loc: Washington state
Reg: 08-14-09
08-02-23 12:12 PM - Post#2861017
    In response to 1971BB427
Check out this link, it is what you need
https://www.12bolt.com/store/p560/SIDE_MOTOR _MOUNT...
Ed
1941 Master Deluxe 2 door sedan- 283/TH350
1950 Fleetline 2 Door project
1950 Styleline 4 Door sedan
1951 Ford Deluxe 4 door sedan- 302/AOD
Still confused after all these years!
asahi1234
Reg: 06-19-14
09-09-23 02:27 PM - Post#2862420
I have a 700r4, driveline and rearend from a 89 S10. What rear leaf springs would I use? Any help would be greatly appreciated.
1971BB427
Loc: Portland,Or
Reg: 12-06-09
09-14-23 08:30 AM - Post#2862568
Simplest would be to use the stock leaf springs, or stock replacements. But you'll need to cut the perches off the S10 axle and get perches for a 1.75" spring, and weld them on at the correct width.
I don't know of any simpler, or cheaper way to install the S10 axle.
asahi1234
Reg: 06-19-14
11-16-23 07:11 AM - Post#2864208
I have collected more parts here is my list of parts. I think I am going to go with Heidts crossmember. Any negative on using Heidts crossmember? What should the engine, Transmission, drivelin degree should be? What gear ratio should I put in the rearend? I plan on it to be a cruiser and be able to keep up with other cars on the highway? Thank yor for your help.
1. 230 engine
2.700r4
3. S10 rearend and driveline.
Edited by asahi1234 on 11-16-23 07:15 AM. Reason for edit: No reason given.
Execution time: 0.12 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:52 AM
