Airlifter
Reg: 06-07-15
06-11-23 04:44 PM - Post#2859060
I had to remove the drive train to change pilot bushing and throw out bearing. On re assembly I noticed that two of the three bolts mounting the transmission to the cross member are 3/8 and the other is 7/16. Is this normal or maybe the one bolt hole has been stipped and drilled to accept the 7/16 bolt?
By the way, I learned a Lot during this process.
Thanks, Pete
1951 styline deluxe sport coupe w/'60 261 engine & 54 powerglide
1965 Corvair Corsa 140 hp 4 speed convertible |
