Username Post: Crank sensor not grounding out        (Topic#373238)
Ropeburn33
Reg: 06-03-23
06-05-23 10:39 PM - Post#2858808
1998 k1500 5.7 vortex motor replacement crank sensor new but won't fire the coil can pull plug off crank sensor and plug extra sensor up and touch it to a good ground and the coil will fire plug it behind balancer and nothing changed sensor 3times rotor twice distributor 2times as well as coil and ignition module3 times overlooked whole wiring harness
Edited by Tony on 06-06-23 06:03 AM. Reason for edit: Moved to proper forum
rcr3
Site Ambassador -"19th Year" Silver Supporting Member
rcr3
Loc: MANHEIM PA. U.S.A.
Reg: 11-24-02
06-06-23 05:18 AM - Post#2858814
    In response to Ropeburn33
Welcome! I would post this in the proper truck forum,farther down the page.VVVV
'67 Camaro survivor
'06 Z71 Sierra Ex Cab
'37 Chevy cp.SOLD!!6/7/14
'73 Nova pro-street project
'17 Chevy Trax LT
Execution time: 0.329 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:24 AM
