Username Post: 71 turn signal        (Topic#373129)
J C
Loc: Orange Co. Calif
Reg: 04-17-04
05-20-23 05:29 PM - Post#2858120
Lately I fix one thing and something else pops up.
Now the passenger side turn signal does not flash.
Drivers side works. Running lights on both side work. Power is good to turn signal socket if there is no bulb in either front or rear. Put bulb in rear I loose power to the front. i did not try these other way around. It got late and I got tired so i was done for the day. I will check wiring tomorrow. I hope its not in the steering column. Suggestions will be helpful. Thanks.
69RSZ28 71 Chevelle 79 Silverado 24K mi.
J C
Reg: 04-17-04
05-21-23 09:33 AM - Post#2858135
    In response to J C
Finally, with help, the problem was a directional switch in the column that sometimes did not make good contact. Still don't know why it was sending power to the rear but not the front.
J C
Reg: 04-17-04
09-16-23 03:14 PM - Post#2862599
    In response to J C
Car sat to long. Turn signals worked just had to wiggle the lever a slight bit. Bad connection.
Execution time: 0.109 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:29 AM
