Username Post: 305 V6 Starter        (Topic#372987)
65acadian
65acadian
Loc: Manitoba, Canada
Reg: 08-15-04
04-26-23 02:58 PM - Post#2857312
I was in a wrecking yard yesterday and saw an engine in a pile that looked like a 305 V6 (I'm from Canada, we never had those here in our pickups, so I know only a little bit about them).
Anyway, the cast iron starter nose on it looked very much like the starter nose the passenger cars with the bigger flywheel used (on 4 speed applications) as well as what the pickups used in the late 60's. Does anyone know if that is actually the same nose? It uses two identical length vertical bolts about 3 5/8" long if I remember correctly.
Thanks.
Edited by 65acadian on 05-14-23 08:48 PM. Reason for edit: No reason given.
fritz1990
fritz1990
Loc: Kansas
Reg: 02-16-03
04-26-23 07:20 PM - Post#2857319
    In response to 65acadian
I have worked on a lot of old 305-351 years ago. If I remember correctly they were two bolt that ran horizontally. These were all in grain trucks. The pickups may have been different.
Regards, Jeff
1998 K1500 6.5 Coal burner
1965 C10 with 498 BBC AFR Heads
1964 C10 Ran 348W for 6 years, now SBC.
Corvettes owned: '74 '77 '78 L82 Silver Anniversary, 2002 LS1, 2007 C6 Love this one! Now have 2014 C7
Don't have a nervous come together!
65acadian
65acadian
Reg: 08-15-04
04-26-23 07:48 PM - Post#2857320
    In response to fritz1990
Well I was wondering. After I posted this I tried looking up a starter and I found what you described. This engine was upside down in a pile but the valve covers sure looked like the 305 valve cover and the starter was a Delco. At first I thought I'd found one on a 350 or something, and then once I started looking at the engine saw that's not what I was looking at.
Execution time: 0.102 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:21 PM
