Username Post: alignment specs?        (Topic#372802)
rod
Member #248 Senior Member
Loc: kingman,az
Reg: 04-29-00
03-25-23 07:43 PM - Post#2856123
my neighbor has a 55 Chevy truck, which has the Camaro sub frame.
2?s. does the upper control arm use the std. old style alignment shims between the shaft and frame?
what are the alignment specs for a real camaro?
thanks Rod in AZ
03-26-23 06:46 AM - Post#2856128
    In response to rod
What year Camaro? I have the specs up to 86. Older Camaro front ends used shims, either look at the truck or find the year the subframe came from.
Edited by Shepherd on 03-26-23 10:03 AM. Reason for edit: No reason given.
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
03-26-23 10:46 AM - Post#2856142
    In response to rod
If it were my vehicle, I would start with the alignment specs of the donor car and then find an alignment shop that understands how your vehicle's settings might need to be different.
03-26-23 11:04 AM - Post#2856145
    In response to rod
camaro specs are probly a general guideline. i would just wing it depending on wheel size, offset, vehicle size and weight.
03-26-23 11:21 AM - Post#2856146
    In response to bobb
Agreed, the stock specs are really a starting point for the oe design of the suspension and steering. The final adjustment for caster and camber portion would be tailored to the truck.
Edited by Shepherd on 03-26-23 04:52 PM. Reason for edit: No reason given.
Execution time: 0.124 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:50 PM
