mean60impalagene
Reg: 01-31-13
03-18-23 10:20 AM - Post#2855899
Has anyone changed the carb from thee mono carb to an upgrade?
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
03-18-23 03:35 PM - Post#2855903
In response to mean60impalagene
If you are running three Monojets, that's a considerable upgrade from the factory setup. The engine can definitely pull in more air as you have tripled the intake capacity.
I see going any other route as a waste. Be sure that you have a free flowing enough exhaust to be able to handle the additional intake airflow.
People fear change because it threatens what they know, or what they claim to know. |
03-19-23 11:28 AM - Post#2855925
ive heard of holley weber 2 barrel conversions. you wont get tons of power out of that engine. i would do a compression test, better yet a cylinder leakdown test and cam inspection before spending any money on it.
Tony1963
Reg: 07-09-18
03-19-23 12:00 PM - Post#2855930
In response to bobb
That's a great point. That engine was never known as a horsepower giant, but that little inline six made enough torque to move each of the Chevrolet vehicles (except Corvette) over its lifetime as the base engine.
Perhaps it is best served in its stock configuration?
mean60impalagene
Reg: 01-31-13
03-20-23 07:24 PM - Post#2855984
In response to bobb
I have a machined 73 250 4.1 engine that I what to get a better carb. on it. I only want one carb not three.... It is going with a auto trans.
Tony1963
Reg: 07-09-18
03-21-23 01:41 AM - Post#2855987
Ah...ok. Understood.
Adding a carburetor might not be the answer to additional horsepower. But, you could source an old Dualjet which is a Rochester 2-bbl carburetor from the 60s/70s that might help.
However, make sure that your carburetor is sized for your engine. Using a Dualjet from a V8 without modifications will only make it run badly.
Remember, the factory used the Monojet on these and they ran quite well.
Tony1963
Reg: 07-09-18
03-21-23 11:47 AM - Post#2856000
Another carburetor to consider for GM vehicles is the Varajet which is essentially a staged 2-bbl carburetor. Think of it as a Quadrajet concept with only one side, one primary and one secondary.
https://nationalcarbureto rs.com/Chevrolet-GMC-Truc...
Stinky
Loc: Whitewater, CO
Reg: 05-25-01
03-23-23 08:08 PM - Post#2856071
In response to Tony1963
How about fuel injection?
Holley makes 1 bbl, 2 bbl (of at least 2 dif types, and big FI units....towards the bottom of the page.
https://www.holley.com/products/fuel_systems /fuel_...
Tony1963
Reg: 07-09-18
03-24-23 01:57 PM - Post#2856085
In response to Stinky
Yes, I agree that fuel injection would be a great upgrade. I was getting the idea that he wanted to stick with a carburetor so I offered that as an option.
