Username Post: Power steering what box fits?        (Topic#372768)
probelair
probelair
Reg: 11-01-19
03-15-23 02:15 PM - Post#2855831
Bought CPP box and stuff and after notching the radiator it still doesnt fit well. Is there a better choice?
327
Loc: Ontario , Canada
Reg: 02-09-21
03-15-23 06:03 PM - Post#2855840
    In response to probelair
YES THE ORIGINAL ONE THAT CAME WITH THE CAR. :cool :
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
03-15-23 06:35 PM - Post#2855842
I will try to give a more productive response since it appears that you are looking for a quicker ratio steering box.
https://www.ebay.com/itm/144957706550#LIST ING_FRAM...
dgstarr
dgstarr
Loc: Portland, OR
Reg: 04-16-13
03-16-23 09:51 AM - Post#2855853
You don't say what car you have or if it has power steering. Lares 18633 is a fast ratio gear box that is a direct replacement for a 59-64 Impala with power steering. Rockauto has it for $304.79.
dgstarr
dgstarr
Loc: Portland, OR
Reg: 04-16-13
03-16-23 09:51 AM - Post#2855854
Edited by dgstarr on 03-16-23 09:52 AM. Reason for edit: No reason given.
327
Reg: 02-09-21
03-18-23 08:00 AM - Post#2855896
    In response to dgstarr
:cool :
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
03-19-23 08:49 AM - Post#2855919
    In response to Tony1963
$1400 are they nuts!
Tony1963
Reg: 07-09-18
03-19-23 02:20 PM - Post#2855934
    In response to turbo38s10
Yes, I understand. Consider it a starting point. There are boxes out there that have a guaranteed fit and have been converted to a high ratio. Back in the day, the slow steering ratio was what people wanted, today it is different.
I attempted to provide a more constructive response than to tell you to install the OE box, which it did not appear to me that you had interest in doing.
69_BOWTIE
Loc: WYOMING,USA
Reg: 02-27-02
03-19-23 06:13 PM - Post#2855939
I just put a P.S. box in my 63 327 no notch rad, and it fit. It is a Borgenson box and it came with a plate that bolts on the frame then the box bolts to plate. I bought the kit from the classifieds it looks alot like the CPP kit
2001 Silverado 4X4
2005 FXDWGI
69 CHEVY C-10 Short Step 327
63 IMPALA 2/DR HRDTOP 327
61ragtop
Loc: Langley B.C. Canada
Reg: 07-30-03
03-20-23 02:38 PM - Post#2855965
    In response to 69_BOWTIE
Borgeson has one..... I recommend having a steering pro go over it and have it adjusted, the place I got mine from says they are often over adjusted from new making them less than ideal for handling.
Edited by 61ragtop on 03-20-23 02:39 PM. Reason for edit: No reason given.
sanee64
Loc: atlanta ga
Reg: 04-05-18
03-22-23 11:28 AM - Post#2856034
I bought a borgeson ps and was told i needed a notch on the radiator (decided to get an aftermarket rad as original was leaking bad)
ANyways i didnt need it as it would have cleared it (by a couple mm)
dgstarr
dgstarr
Loc: Portland, OR
Reg: 04-16-13
03-22-23 12:15 PM - Post#2856038
The Lares fast ratio steering box is the same size as the original GM units and does not require a notched radiator.
Gator1963SS
Loc: Tampa
Reg: 06-30-09
03-27-23 05:28 PM - Post#2856202
    In response to sanee64
I have a 62 and put the Borgeson 800106 in with that bracket and it is way off. It points too low and directly at the cross member. I guess I'm going. to have to reconfigure the geometry and make a new bracket? Anyone have this problem?
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
03-27-23 07:49 PM - Post#2856211
    In response to Gator1963SS
Yes I had a new mounting bracket made in Aluminum.
It was made using a computer program.
I still have the bracket and a complete global west front steering with the Borgenson steering box
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
https://paulstensland.com
Execution time: 0.101 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:24 PM
