Username Post: Clutch issue / will not disengage.        (Topic#372764)
Boomslang57
Reg: 04-19-22
03-14-23 05:14 PM - Post#2855807
My '57 Chev, with stock 283 engine has a new clutch. The clutch will not fully disengage, with the adjustment at max, with no pedal depression remaining before hitting the floor... the clutch pedal is way too hard to depress for a stock pressure plate install. Seems like something must have been installed wrong. or a faulty part in the assembly. Any ideas as to cause and cure? Thanks. Boomslang
Edited by Tony on 03-16-23 05:02 AM. Reason for edit: Moved to correct forum
rcr3
Site Ambassador -"19th Year" Silver Supporting Member
rcr3
Loc: MANHEIM PA. U.S.A.
Reg: 11-24-02
03-15-23 04:51 AM - Post#2855816
    In response to Boomslang57
I'd post this in the '55-'57 forum. Scroll down.
vvv
'67 Camaro survivor
'06 Z71 Sierra Ex Cab
'37 Chevy cp.SOLD!!6/7/14
'73 Nova pro-street project
'17 Chevy Trax LT
55MAS
Loc: North Coast, USA
Reg: 12-19-01
03-16-23 05:33 AM - Post#2855846
Assuming that the clutch pedal travel was fine before and that you bought the correct length throw out bearing (there are two), I would suspect that the fork/bearing is not correctly connected.
Did you check the fit at the bearing onto the input give for no binding/tightness?
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
03-17-23 05:45 AM - Post#2855875
    In response to 55MAS
Agree. The standard GM pressure plate ('flat' springs) requires the 'long' throw out bearing. The 'short' bearing is used for the pressure plates with 'curved' springs.
Pete
Execution time: 0.087 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:24 AM
