Username Post: Hood adjustment        (Topic#372746)
Mike7231
Loc: Bardstown, KY
Reg: 06-08-18
03-13-23 06:47 AM - Post#2855705
I need some advice from those who have messed with hood adjustments. I'm finally getting my 1956 chevy truck back together. Engine is in and running, inner fenders and outer fenders are on and mated up great, I put the hood on last night, and it is almost a perfect fit, with all the gaps looking great. My problem is, when I raise the hood and lower it back down, the back sticks up about 3/4 to 1", all the way across. I can push it right down into place with no problem, and it looks great. Is there an adjustment that I'm not doing right? These are, I believe the original hood hinges, and were in great shape. I also have plenty of tension in the springs.Thanks for any advice.
monty56
"18th Year" Gold Supporting Member
monty56
Reg: 04-26-04
03-13-23 09:15 AM - Post#2855710
    In response to Mike7231
Push the hood hinge mount UP a bit at a time. The hinge goes over center so needs to go up for the hood to go down. Hope this helps.
Monty
2001 Chevy Suburban 2500
2009 Saturn Vue w/20's
Monty's 56 Truck
Avatar is my Truck
Mike7231
Loc: Bardstown, KY
Reg: 06-08-18
03-14-23 02:23 AM - Post#2855758
    In response to monty56
Thanks! I'll give it a shot one night this week.
monty56
monty56
Reg: 04-26-04
03-14-23 09:22 AM - Post#2855781
I actually had to grind out the bottom of the hinge holes maybe 1/8th" to get the hood down.
Monty
Monty's 56 Truck
Avatar is my Truck
WagonCrazy
"17th Year" Platinum Supporting Member
WagonCrazy
Reg: 06-07-05
03-14-23 12:02 PM - Post#2855793
The hood on my 59 apache does the same thing (sits high in back when closed).
This is good advise Monty56. I'll try this hinge adjustment soon too.
Mike7231
Loc: Bardstown, KY
Reg: 06-08-18
03-27-23 03:48 AM - Post#2856167
Finally had the chance to make this adjustment, and it worked perfect!!! Thanks again for your help..
monty56
monty56
Reg: 04-26-04
03-27-23 09:16 AM - Post#2856184
You are welcome, That's what we are here for.
Monty
Monty's 56 Truck
Avatar is my Truck
Execution time: 0.071 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:31 AM
