smithd7
Loc: Coburg,Oregon,U.S.A.
Reg: 11-07-01
03-12-23 12:38 PM - Post#2855679
the data plate reads 53680 which is a sprint custom would this also be a SP? If not would a data plate show SP info?
'61 Impala HT,
'63 Nova SS convertible,'99 C-5 convertible, '72 GMC Sprint SP |
SSuper Dave
Loc: Pearland TX
Reg: 10-02-05
03-12-23 05:20 PM - Post#2855696
In response to smithd7
SP was an option and vin woud not show that. UNLESS the 5th digit is a W, then the original engine was an LS-5 454, available in SP only. Other engines available in an SP would be the L-48 350 4bbl, and the LS-3 400 (396) big block, VIN 5th digit code U. Bu those engines were availble in non SP Sprints as well. To know for sure, you need to see the W in the VIN, or a build sheet for the other two engine calling out the YE7 SP option.
1968 Caprice coupe, 327/275, TH400, Ash Gold/Ivy Gold, Tach Dash, Tilt, Buckets, Console, AM/FM, Rear Defog, Disc and Rallys.
1970 El Camino, 350, TH400, 12 bolt posi, a blank slate! |
smithd7
Reg: 11-07-01
03-12-23 10:53 PM - Post#2855701
In response to SSuper Dave
Thanks Dave, yes the W is a true sprint SP. A standard sprint would have a vin starting with 5C80
While a '72 custom Sprint would have a vin starting with 5D80. I do not have the original engine in my Sprint so that's why I am asking if there is a way to tell from the data plate if I have a true SP.
Thanks again
'61 Impala HT,
