Username Post: carpet for AFTER you remove the in cab fuel tank        (Topic#372693)
MendoK20
MendoK20
Loc: CA
Reg: 12-24-22
03-05-23 10:32 AM - Post#2855357
So i'm getting all my ducks in a row to remove the in-cab fuel tank, and do the under the bed blazer tank. I would have sworn i had seen a carpet kit that goes where the in-cab fuel tank is, for after you remove it....? Any of you guys seen that? I'm not having any luck finding anything now.
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
03-05-23 01:12 PM - Post#2855366
    In response to MendoK20
Are you looking for carpeting to run up the back of the inside of the cab wall or under the seat?
gcrkfrd
"6th Year" Platinum Supporting Member
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
03-05-23 04:25 PM - Post#2855376
    In response to Tony1963
Check LMC Truck
1952 Styleline Sedan-
Yellow 1994 Bronco.
T-Bucket, Small Blocks, and parts everywhere
MendoK20
MendoK20
Loc: CA
Reg: 12-24-22
03-07-23 01:14 PM - Post#2855470
    In response to gcrkfrd
I checked LMC, and didn't see the kit i am looking for. Tony1963, i'm looking for the carpet piece that just fills where the tank was sitting, so maybe like 8" on the ground, then the rest up the back side. Make sense?
Tony1963
Reg: 07-09-18
03-07-23 04:37 PM - Post#2855483
Yes, that's what I wondered if you were asking.
I seem to recall something from the past, but not sure. I remember some type of frame that fits in the rear of the cab that holds the carpet vertical. There's nothing there to attach the carpet to, so other than gluing it in place or fabricating something, I'm not sure how you would hold it.
I had a Ford pickup (Lariat model) back in the 90s that was premium trim and it had carpeting behind the seat. As I recall, there was a trim piece that held the carpet and they had some padding behind it to give it a finished look.
MendoK20
MendoK20
Loc: CA
Reg: 12-24-22
03-20-23 01:42 PM - Post#2855963
Ok, Thanks Tony
Execution time: 0.112 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:33 PM
