MendoK20
Loc: CA
Reg: 12-24-22
03-05-23 10:32 AM - Post#2855357
So i'm getting all my ducks in a row to remove the in-cab fuel tank, and do the under the bed blazer tank. I would have sworn i had seen a carpet kit that goes where the in-cab fuel tank is, for after you remove it....? Any of you guys seen that? I'm not having any luck finding anything now.
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
03-05-23 01:12 PM - Post#2855366
In response to MendoK20
Are you looking for carpeting to run up the back of the inside of the cab wall or under the seat?
People fear change because it threatens what they know, or what they claim to know. |
gcrkfrd
"6th Year" Platinum Supporting Member
Loc: Neosho, MO.
Reg: 04-01-18
03-05-23 04:25 PM - Post#2855376
In response to Tony1963
Check LMC Truck
1952 Styleline Sedan, 62-235, Drum brakes, Manual steering, 2" Drop, 8-60 AC, Glass packs, Two Carbs, and a Cast Iron PowerGlide-
Way out behind the Old School
Half a Dozen in a Row, all it needs for Her to go.
MendoK20
Loc: CA
Reg: 12-24-22
03-07-23 01:14 PM - Post#2855470
In response to gcrkfrd
I checked LMC, and didn't see the kit i am looking for. Tony1963, i'm looking for the carpet piece that just fills where the tank was sitting, so maybe like 8" on the ground, then the rest up the back side. Make sense?
Tony1963
Reg: 07-09-18
03-07-23 04:37 PM - Post#2855483
Yes, that's what I wondered if you were asking.
I seem to recall something from the past, but not sure. I remember some type of frame that fits in the rear of the cab that holds the carpet vertical. There's nothing there to attach the carpet to, so other than gluing it in place or fabricating something, I'm not sure how you would hold it.
I had a Ford pickup (Lariat model) back in the 90s that was premium trim and it had carpeting behind the seat. As I recall, there was a trim piece that held the carpet and they had some padding behind it to give it a finished look.
MendoK20
Loc: CA
Reg: 12-24-22
03-20-23 01:42 PM - Post#2855963
Ok, Thanks Tony
