 Page 2 of 2 <12
Username Post: SBC Build        (Topic#372622)
fritz1990
fritz1990
Loc: Kansas
Reg: 02-16-03
03-18-23 06:41 PM - Post#2855906
    In response to 65_Impala
Listen to 65Impala he is spot on! The quench and compression height is important to a good running engine. If you don’t know how to measure these things, ask. IMHO I would bore it, then you would have nice round bores. Don’t put new pistons in an out of round bore. My 5 cents.
Regards, Jeff
1998 K1500 6.5 Coal burner
1965 C10 with 498 BBC AFR Heads
1964 C10 Ran 348W for 6 years, now SBC.
Corvettes owned: '74 '77 '78 L82 Silver Anniversary, 2002 LS1, 2007 C6 Love this one! Now have 2014 C7
Don't have a nervous come together!
CNC BLOCKS N/E
Loc: NORTH EAST
Reg: 12-12-03
03-19-23 09:11 AM - Post#2855920
    In response to Tony1963
There is no real way to measure alignment between housing bores follow the insurrections that come with you ARP kit
Torque plate hone is a must if you want to achieve good ring seal
03-19-23 12:24 PM - Post#2855924
    In response to DuramaxLLY
i hope you are doing your homework. as noted quench is critical, as is piston design. dog dish pistons are junk junk junk. the heads and cam you choose will determine the rpm power band you end up with. look at vizard and holder vortec videos on you tube.
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
03-19-23 01:03 PM - Post#2855931
I've used cast flat-top pistons before without issues. But, I wasn't trying to build a 400 HP engine, either.
I suspect that he is looking for a budget upgrade in performance, thus, I steered him toward the cast piston if needed.
1983G20Van
Loc: Hurst, Texas, USA
Reg: 11-13-02
03-19-23 07:23 PM - Post#2855940
  • DuramaxLLY Said:
Alright finally got around to taking it to the machine shop. It’s already bored .30 over. I want to just hone it but if not we’ll go to .40.
Gonna keep the crank and rods. I’ll order some flat top hypereutectic pistons. Their weight will be about the same as stock so I shouldn’t need to rebalance.
I’ll ARP stud the bottom end. Line Hone is expensive so if the caps still line up nice I might skip that.
For heads, he recommended staying 185cc and below for better responsiveness on the street. Once I pick out a set of heads we’ll match the correct cam.
Now let’s see if I can stay under budget!
As for smaller than 185cc it is a pipe dream that they make more torque. I put 200cc advertised (more like 195cc in reality) aluminum heads on my old 350 Vortec in my heavy Express van when the garbage mexican Vortecs cracked. They made noticeably more power everywhere. When I built the 383 I had Lloyd Elliot port a set of those same heads for it. Up to about 210-215cc (varies a bit port to port). They flow ~300 cfm @ 0.600 and I have 0.578 lift. I make ~500 hp at the crank with a 218/228 @ 0.050 roller cam cut on a 108 LSA and it leaps to life. Loads of torque. The better the heads flow the smaller the cam can be to make a given power. The smaller the cam, the more off-idle torque, throttle response and fuel mileage you will have. The cam specs above make peak power at 5,600 rpm and peak torque about 3,500 rpm. Its over 500 ft/lbs at 3,500. The 383 moves my Express that weighs just shy of 7,000 lbs like it is 3,000 lbs lighter.
65_Impala
Reg: 12-29-02
03-20-23 04:26 AM - Post#2855948
Which today is a hypereutectic piston. You obviously don't know what you're talking about anymore if you think cast pistons that are not hypereutectic is still a thing people should use.
03-20-23 05:55 AM - Post#2855949
You can still buy "plain jane" cheaper regular cast pistons, next step up are the better Hypereutectic cast pistons that are superior to regular cast and can handle much more power. Pretty sure we all know this.
Edited by Shepherd on 03-20-23 05:56 AM. Reason for edit: No reason given.
65_Impala
Reg: 12-29-02
03-20-23 08:46 AM - Post#2855950
Enlighten me then. Where do you get a 4.030" bore, 1.56" compression height cast piston then that are so much cheaper than a set of hypereutectic it's even worth considering them?
Sets of 8 Hypereutectic pistons for a 350 start at around $195.
Sets of 8 cast non hypereutectic pistons for a 350 start at around $180 and they have the wrong compression height.
I never said plain cast pistons are no longer available.
But, it is complete stupidity to use plain cast pistons in a 350 small block build that you are doing as a performance build.
03-20-23 10:29 AM - Post#2855958
I would never use basic cast pistons in any build, I wasn't challenging anyone's ideas, just info in case someone wasn't aware of the different types of cast pistons.
 Page 2 of 2 <12
Execution time: 0.118 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:02 PM
