Username Post: light scratches & swirl marks        (Topic#372590)
smithd7
Loc: Coburg,Oregon,U.S.A.
Reg: 11-07-01
02-15-23 12:50 PM - Post#2854532
What is the best compound to remove scratches and
swirl marks.
'61 Impala HT,
'63 Nova SS convertible,'99 C-5 convertible, '72 GMC Sprint SP
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
02-16-23 04:07 PM - Post#2854586
    In response to smithd7
3M products are best. Each has a certain amount of abrasive material that will smooth the paint.
I usually try polishing compound first. You can go up or down from there. If the polishing compound does the job, then apply another buffing one step finer and finish with some type of wax.
Keep in mind that all of this removes a certain amount of clearcoat. There is no "erasing" these swirl marks, you end up cutting enough material off to make the surface flat.
Do not use anything coarse as you will cut through the clear, then you're going to have to repaint and reclear that section.
Also, keep the buffer moving around and do not burn the finish.
Sting Ray
"19th Year" Silver Supporting Member
Sting Ray
Loc: Westwood Hills, Kansas
Reg: 02-19-05
10-22-23 06:29 PM - Post#2863501
    In response to Tony1963
There’s other products besides 3M. Mothers, Griot and more. Start with the least abrasive and work up from there. Maybe do it by hand first before using a buffer.
Bleeds Chevy Orange
1955 Bel Air hardtop, 327, 4-spd, tilt front end
1964 Corvette two top convert, 327, 4-spd
1967 El Camino, 427, 4-spd
2022 Corvette coupe, Arctic white, red stripes, 3LT Morello Napa leather
Execution time: 0.425 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:22 AM
