Username Post: Grounding A Pwr Seat        (Topic#372535)
TR56210
Reg: 10-28-18
02-05-23 01:14 PM - Post#2854156
Reached the point in my build of 56 sedan, where I am installing power bucket seats ( from a 2 dr Lincoln Mark ). In testing seat functions by direct connect to battery, prompted a couple of questions.
I have available fused power key on or key off from my fuse panel.
Which would you use?
I assume, because I am not looking at the car, that fused pwr will be one wire and capable of supporting both seats. Right?
Ground wire. If my one wire assumption is valid, do I ground the seats to floor or do I need to run ground to battery?
Appreciate the groups input.
55MAS
Loc: North Coast, USA
Reg: 12-19-01
02-06-23 08:49 AM - Post#2854185
    In response to TR56210
Most power seats are supplied from key off (enables seat adjustment before starting car).
If power is supplied to two seats then both are powered. Bolting the seat to the floor grounds them, assuming that you have a braded cable connecting the body to the frame & battery. A good body ground as above is needed for the higher power of the seats compared to lower power items like heaters, lights ect.
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
02-06-23 01:35 PM - Post#2854191
First, make sure that the circuit that you are using can handle the amps of the power seat motors. I would add a circuit breaker or separate fuse to that circuit as well.
As far as the grounds, I'd imagine that the ground is through the wiring harness to some body ground somewhere. I doubt that the seat in the Lincoln was grounded to the body so you will have to examine the inbound wiring harness to the Lincoln seat to see how Ford engineered that circuit.
TR56210
Reg: 10-28-18
02-06-23 07:21 PM - Post#2854203
    In response to Tony1963
Thanks guys can add body ground from battery.
4dr 57
4dr 57
Loc: Texas Hill Country
Reg: 11-10-04
02-12-23 08:54 AM - Post#2854406
If wanted, you could add another complete battery based circut through a block of relays for more than just the seats that will make a regulatable system in all directions, using simply bigger wire, not battery specific cables.
Ground your battery to the transmission housing for things engine related.
I put a seperate neg. cable from the belhousing to the body (by the steering column I think) but that's just me probably.
It's all good. Mostly
Execution time: 0.128 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:52 PM
