Username Post: shift indicator        (Topic#372532)
bikernut
Loc: NEW HAMPSHIRE
Reg: 02-04-03
02-05-23 08:19 AM - Post#2854147
on my 2003 GMC 3500 4x4 6.0 engine I notice when plowing that my shift indicator doesn't go into #1 it just goes to #2 and stops at the travel limit. is this an indicator that the shift cable is going to break soon? it seems okay when shifting into reverse but I did notice if I put it in neutral and hit the throttle the truck seem to be slightly in Drive for a few seconds when driving it. stopped it seems fine.
3500 Dually Member # 252 and Damn proud of it
2020 GMC Acadia Denali
1992 Chevy S-10 4X4 Blazer
2015 Harley FLHTCUTG
2003 GMC 3500 Dump
87 Pontiac Trans AM GTA
jktucker92
jktucker92
Loc: West Richland, WA
Reg: 02-05-17
02-07-23 07:21 AM - Post#2854211
    In response to bikernut
The shift indicator is fed by a switch on the outside of the transmission. It can be adjusted slightly by loosening the two screws and rotating it a bit. That could solve the issue with the indicator being off. That would not cause it to be in drive briefly while in neutral though. The detents are inside the transmission.
Execution time: 0.072 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:18 PM
