Username Post: V8 Throwout bearing        (Topic#372500)
Chevi
Loc: Eastern NC
Reg: 07-13-08
01-30-23 06:35 AM - Post#2853909
Parts manuals are not clear as to which throwout bearing is correct for V8's and 6 cylinder engines. The pressure plates are usually of the diaphragm spring type or the three finger style.
1. Which bearing is used (short or long) with all original 57 V8 parts and the new diaphragm type presure plate?
2 Is the three finger type pressure plate still available, and which bearing would be used for this application?
Thanks for your support, Chevi
Edited by Chevi on 01-30-23 06:36 AM. Reason for edit: No reason given.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
01-30-23 08:58 AM - Post#2853917
    In response to Chevi
The simple answer is:
If the 'fingers' on the pressure plate are the 'flat' type; the long throw out bearing is applicable.
If the 'fingers' are the 'long/bent' type the 'short' throw out bearing is needed.
In 55-57, I don't believe GM only used anything but the 'flat' type pressure plate, regardless of V8 or in-line 6 engines.
With aftermarket clutches, the same criteria apply. 'Flat' fingers = long bearing; 'long/bent' fingers = short bearing.
That criteria places the throw out bearing in the same location/position on the 'shaft'. This conserves the geometry of the the system.
Pete
Edited by japete92 on 02-06-23 05:14 PM. Reason for edit: No reason given.
Chevi
Loc: Eastern NC
Reg: 07-13-08
02-06-23 08:18 AM - Post#2854182
    In response to japete92
The long/short throw out bearing situation has been giving me a problem for a long time. Thanks for clearing up the requirement for using a short bearing with Long/Bent fingers. Chevi
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
02-06-23 06:03 PM - Post#2854201
My comments would've been clearer if I had not double talked. I edited my comments to correct my mistake.
Pete
Execution time: 0.073 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:32 PM
