63bob
Loc: WA
Reg: 02-02-01
01-29-23 04:38 PM - Post#2853892
Both front bucket seats in my 63 Convertible sit very up right and are very Uncomfortable. Really bad on a long ride. Has anyone ever raised the front seat mounts to lean the seat back a few degrees? This seems like a no brainer, but the inside seat mount is a bracket welded to the floor with a threaded stud that the seat slips over. I thought about removing the rubber seat stops at the back of the seat, but that is a visual no no. Do you have the same problem or a fix?
1963bob
63 Impala SS Convert 4spd, 3:70 Posi, 377ci-AFR180 Heads-Comp 276HR-6"rods-10.3:1
Currently: Started engine 04-15-11, after 14-year restoration. Finally on the Street Summer of 2011 |
Edited by 63bob on 01-29-23 04:39 PM. Reason for edit: No reason given.
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
01-29-23 05:37 PM - Post#2853896
In response to 63bob
All the factory 62, 63 & 64 SS Impalas had two studs on the inside mounts ( for each bucket seat) to mount the buckets to the floor pan. One stud is horizontal and one stud is at 45 degrees from horizontal.
All the outside floor mounts closest to the doors have 4 studs on the each floor mount on both seats
Do you have the correct factory floor mounts( as noted above) and the correct factory bucket seat brackets for a factory SS car?
If the SS floor brackets were added to the floor ( not factory installed ) they could have been installed incorrectly.
Pictures of your floor and seat brackets?
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
https://paulstensland.com
63bob
Loc: WA
Reg: 02-02-01
01-29-23 06:07 PM - Post#2853898
In response to pvs409
Paul: Yes it is all Factory just as you described. This is an original SS convertible car. It would be easy to just shim up the front outside mounts but the front inside mount stud is from the factory in a fixed horizontal position.
I need to get set up for pictures but haven't done that yet.
pvs409
Reg: 01-10-05
01-29-23 09:19 PM - Post#2853905
you could make the brackets like these -yet modify them to raise the front of your seat up.
These brackets were made to move the seats back from the factory mount location
Site Ambassador
02-02-23 09:07 PM - Post#2854076
Can you trim the bumpers down so that they are still there but allow the seat back to go back further?
1957 Cameo Carrier |
