Username Post: New blower motor quit        (Topic#372444)
xstuntman
Loc: west Texas
Reg: 04-13-09
01-23-23 06:39 AM - Post#2853635
Just got to work and on the way the new blower motor was working for half a minute, then quit just as I switched over to defrost. Assuming that was just coincidence on the timing.
Haven't looked but betting on the fuse since it popped with the old squeaky motor too. Is there a resistor or something else in line I should be looking at? Gonna be a cold one tonite and probably need the defrost in the morning.
Liberty Valance
Liberty Valance
Loc: Euless,Texas
Reg: 07-21-14
01-23-23 08:12 AM - Post#2853645
    In response to xstuntman
If you have a meter, turn fan switch on and test connector on motor to confirm voltage and work from there.
1974 Cheyenne 10 LWB STOCK 350 W/HEI /TH350 /AC/ 4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
01-24-23 04:53 AM - Post#2853665
    In response to Liberty Valance
The fan speed resistor is located on the evaporator housing. Slightly up and right of your blower motor. If the fan is squeaky, replace it. It's eating amps to spin. The amps will blow fuses. You can buy a motor with or without a squirrel cage. The OEM squirrel cage can be swapped over.
'08 GMC Acadia 3.6L SLE
xstuntman
Loc: west Texas
Reg: 04-13-09
01-24-23 07:51 PM - Post#2853706
New resistors in and so far no blown fuse. Ran it on the speed just below hi for ten minutes. Too chicken to turn the fan on high yet until this cold front passes thru.
Crossing fingers.
Liberty Valance
Liberty Valance
Loc: Euless,Texas
Reg: 07-21-14
01-24-23 08:41 PM - Post#2853711
What year and model do you have?
Mopar by Birth
Chevy by Choice
xstuntman
Loc: west Texas
Reg: 04-13-09
01-25-23 06:27 AM - Post#2853724
'85 4wd Suburban.
Needed the defroster this morning, slid it on and saw the dash lights flicker, then heard a pop. Makes no sense since it ran for ten minutes the other day.
xstuntman
Loc: west Texas
Reg: 04-13-09
01-25-23 05:06 PM - Post#2853749
Gonna pick up a relay tomorrow and ordered a set of ATC fuse shaped manual reset circuit breakers which should be here Saturday.
xstuntman
Loc: west Texas
Reg: 04-13-09
01-27-23 07:45 PM - Post#2853829
Just FYI,
The set of 5,10,15,20,25, and 30 amp circuit breakers came early. Installed the 25 amp breaker, new blower motor relay, and so far everything works. After some reading a typical bad relay will pop the fuse so hopefully that was my problem.
01-29-23 05:02 AM - Post#2853860
Interesting. Can you post a part number to those circuit breakers?
1983G20Van
Loc: Hurst, Texas, USA
Reg: 11-13-02
01-29-23 11:17 AM - Post#2853872
  • xstuntman Said:
'85 4wd Suburban.
Defrost activates the AC system. On an 85 it should have a throttle kicker solenoid on the carb, wiring to the cycling switch and the a/c clutch. That wiring covers alot of the engine and engine compartment and at the age of the truck, could easily be shorted out. It is very possible your fuse blowing has nothing to do with the blower motor or resistor itself.
I had a problem with my van popping the fuse years ago. It was a shorted diode on the ac clutch connector. I replaced the connector with a new one that included a new diode and never had the issue again.
Edited by 1983G20Van on 01-29-23 11:24 AM. Reason for edit: No reason given.
Execution time: 0.078 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:35 PM
