Prairie Viking
Gold Supporting Member
Reg: 03-11-04
01-22-23 06:42 PM - Post#2853629
I'm working on a 1960 Biscayne with the 235 straight six. The distributor is missing the vacuum advance. In my search, I can't seem to find a complete unit. What I need to find is the clamp that fits onto the distributor body and to the lever on the vacuum canister. I can find all kinds of the vacuum canisters that bolt to the block, but not the actual clamp. If I were to buy a NOS unit on ebay that's still sealed in the box, would it include that? None of the used ones listed show it. What am I not understanding here...?
Once I thought I was wrong, but I was mistaken... |
58Yeoman
Loc: Burlington, Ontario
Reg: 12-22-15
01-23-23 05:50 AM - Post#2853633
In response to Prairie Viking
You might check out this Facebook site:
https://www.facebook.com/groups/55834395768160 9/
It's a Chevy straight six group. Very helpful bunch. I was able to successfully use this site to locate parts to rebuild my 235 last year. John
1958 Chevrolet wagon (Yeoman)
1961 Impala convertible
1958 Impala coupe (parts car) |
1belair1954
Reg: 12-24-12
01-24-23 08:48 PM - Post#2853712
I think the replacement vacuum cannisters do not include the clamp should not be hard to find a used distributor or clamp just be aware earlier model chevs like 1954 the vacuum mechanism is different to later ones.
I know this as I owned a 1954 chev and they sent me a later model and would not work, also with the vacuum cannisters do not buy a NOS one as the rubber in them breaksdown I had a NOS Borg Warner unit and it would not hold a vacuum.
gcrkfrd
"6th Year" Platinum Supporting Member
Loc: Neosho, MO.
Reg: 04-01-18
01-25-23 09:25 AM - Post#2853734
In response to 1belair1954
I have the original distributer, off my 62-235, if you can use any parts.
1952 Styleline Sedan, 62-235, Drum brakes, Manual steering, 2" Drop, 8-60 AC, Glass packs, Two Carbs, and a Cast Iron PowerGlide-
Way out behind the Old School
Half a Dozen in a Row, all it needs for Her to go.
Prairie Viking
Reg: 03-11-04
01-28-23 10:37 PM - Post#2853857
In response to gcrkfrd
I was able to locate one, Thanks.
