chev66c10
Reg: 10-19-22
01-21-23 05:13 PM - Post#2853599
Tail light issues
Ok so here's the issues I'm have. One tail the brake light works, but when I turn the lights on it won't light up. The other light is the opposite. It will light up when the lights are on but the brake light doesn't work. I replaced the bulb on one of the tail lights and still the same issue.
GreatNorthWoods
Reg: 03-31-02
01-22-23 02:56 AM - Post#2853606
In response to chev66c10
Make sure your taillights are well grounded. Weird things like this often occur when there is a lack of proper ground.
Vern
1930 DeSoto Business Coupe- 350 Chevy V8, Edelbrock 600, 4-wheel discs, Wire Wheels, TH400, S-10 Rear, A/C |
fritz1990
Loc: Kansas
Reg: 02-16-03
01-23-23 04:54 PM - Post#2853660
I soldered a wire from each bulb holder and ran it to a clean ground.
Regards, Jeff
1998 K1500 6.5 Coal burner
1965 C10 with 498 BBC AFR Heads
1964 C10 Ran 348W for 6 years, now SBC.
Corvettes owned: '74 '77 '78 L82 Silver Anniversary, 2002 LS1, 2007 C6 Love this one! Now have 2014 C7
Don't have a nervous come together!
Woogeroo
Reg: 05-26-02
01-26-23 02:16 PM - Post#2853787
As others mentioned, check the grounds.
Check the wires from the back to the front.
However, I had a bad headlight switch once, where the lights worked except the headlights.
So, keep that in mind. When they go bad, they act weird.
-Woog
