Username Post: Lap floor pan patch over cross member or...        (Topic#370303)
383 Malibu
Reg: 10-08-08
12-08-22 06:16 PM - Post#2851072
First time doing metal replacement. Replacing part of driver's side floor pan on a 1981 Camaro. Rust does not go any farther back than the front of the cross member under the front edge of the seat. In trying to keep as much factory metal as possible, would it be advised to cut original floor pan on top of cross member right to left, then lap replacement over original floor on top of cross member? Lap joint would not be visible from under the car.
Or, should I go back about another 8" and butt weld? A lot of extra work if I did it this way.
383 Malibu
Reg: 10-08-08
12-10-22 05:13 AM - Post#2851123
    In response to 383 Malibu
Bump
995jim
995jim
Loc: Ohio
Reg: 12-17-06
12-10-22 05:27 AM - Post#2851124
I my opinion I would overlap and either drill out holes for spot weld, then seam seal along the edges or run a welded bead along overlap edge. Im not familiar with your car but my impala has lots of overlapping on the floor pan areas from the factory and then pinch or spot welded together
65' Impala SS, 65' Belair, 89' Silverado Z71, 95' Silverado Z71, 12' Silverado, 15' Silverado LTZ, 16' Tahoe LTZ
Edited by 995jim on 12-10-22 05:27 AM. Reason for edit: No reason given.
Site Ambassador
12-10-22 09:18 AM - Post#2851129
    In response to 995jim
You could do it either way. But honestly I would do the lap joint or a butt weld joint off of the crossmember so the you and get corrosion protection and seam sealer on the welds and joint. If you do it over the crossmember the seam will be inaccessible.
1957 Cameo Carrier
383 Malibu
Reg: 10-08-08
12-12-22 04:56 AM - Post#2851185
    In response to wagonman100
Good points. Thank you guys!
KShortell
Member #1510 Senior Member
KShortell
Loc: Chesapeake, VA, U.S.A.
Reg: 04-14-01
01-11-23 06:11 AM - Post#2853322
A lap joint with seam sealer will suffice. I did it on a '97 Wrangler a few years ago that held up just fine. The new owner is happy.
Like others have said, it is how the factory does it in a lot of places on a vehicle.
Just pay close attention to any areas where a floor pan connects to bracing via welds. It's important to reestablish those connections for structural rigidity.
Good luck!
Semper Paratus
FL05-03 Home Page
Stock is not a dirty word...
Execution time: 0.102 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:08 AM
