Username Post: 1951 12 volt voltage regulator        (Topic#370152)
bobt
Loc: colonial heights va
Reg: 06-28-14
11-23-22 03:03 AM - Post#2850376
Hello. I have a 1951 Chevrolet Fleetline with a 1953 235 six cylinder engine. It's been converted to a 12 volt system with a 12 volt GENERATOR. I need to replace my firewall mounted voltage regulator. My question is-- Will a A/C Delco regulator #D618 work? Yes,I have used the cheaper "Standard" brand in the past but I only get a couple of years out of them so I would like to try an A/C Delco. Thanks, bobt
drtyler
Loc: Georgia
Reg: 05-06-10
11-23-22 06:02 AM - Post#2850377
    In response to bobt
Thats what I would try.
Do you know which generator is on your car? Maybe it is more amps than the Standard regulators have been rated for?
Standard VR20 is rated to 30A, and VR22 is rated for 40A.
For 10 years, I’ve been using a Napa regulator. I asked them for one for a 55 Bel Air with 235. Its been working ok. If I can find something with the part number on it, I will follow up this post.
bobt
Reg: 06-28-14
11-23-22 02:58 PM - Post#2850398
    In response to drtyler
THANK'S! bobt
11-24-22 07:35 AM - Post#2850421
    In response to bobt
In the 1990's I used to go to the local Pick Yer Parts. At that time they were still crushing '49 to '54 Chevy pickups. But I pulled a lot of Delco voltage regulators off then, because I needed one. I didn't have a shop manual, and there was no Internet, so I was guessing at the adjustments. I never did get one right. I finally put a 10si on my '54 truck and never looked back.
11-24-22 02:02 PM - Post#2850449
napa ECH VR126 w/ac
FishFry
FishFry
Loc: Augsburg - Germany
Reg: 11-01-22
11-24-22 10:11 PM - Post#2850464
Yeah, I'm not missing that regulator ether since I got the 10si, but still kept it on the firewall for looks. I'm hiding a modern electronic module and 2 relays in there, since they are not compatible with my engine bay Feng-Shui
Frank
bobt
Reg: 06-28-14
11-25-22 03:06 AM - Post#2850468
I thought about that but I understand that your stock charge gauge won't work? Is that true?
FishFry
FishFry
Reg: 11-01-22
11-25-22 03:53 AM - Post#2850470
    In response to bobt
I think I found a way to make it happen.
The 10 gauge wire to the starter acts as a shunt.
bobt
Reg: 06-28-14
11-25-22 05:52 AM - Post#2850472
    In response to bobt
Ok---I'm assuming the yellow wire is the 10 gauge---What's a shunt? bobt
11-25-22 03:27 PM - Post#2850503
    In response to bobt
I had to use a small exciter light when using the 10si. Also, the damm Chinese are making 10si clones. When I wanted a real Delco 10si, I went to NAPA and looked through their rebuilt alternators until I found a rebuilt Delco. Most were Chinese.
FishFry
FishFry
Reg: 11-01-22
11-26-22 05:01 AM - Post#2850525
    In response to bobt
No the red wire is the 10 gauge and it does the heavy lifting.
A shunt is a device that creates a low-resistance path for electric current, to allow it to pass around another point in the circuit. The origin of the term is in the verb 'to shunt' meaning to turn away or follow a different path.
In a nut shell - a big fat wire that is a super highway for your electric current from the alternator, so most of it will go there, and only a little takes the detour over the ammeter.
Frank
Execution time: 0.109 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:38 PM
