Username Post: Get a 2500 Suburban or Convert the 1500 4x4 to 4L80?        (Topic#370149)
Ajvov
Reg: 08-31-20
11-22-22 06:12 PM - Post#2850369
I got a 01 4x4 Suburban and i want to swap in a 4l80. From the research i've done it seems pretty involved and I'm equipped to do it but is it worth it or should I just get a 2500?
jktucker92
jktucker92
Loc: West Richland, WA
Reg: 02-05-17
11-23-22 02:14 PM - Post#2850396
    In response to Ajvov
You're probably best off just getting a 2500. While it can be done, it's a lot of effort. Also, what is the reason behind wanting a 4L80e? If it's for towing, then the brakes and upgraded suspension of the 2500 makes it a better towing vehicle. The 4L60E is a capable transmission if it's not abused. For moderate towing, as long as it has a tow package (including hitch and tranny cooler) it should last quite awhile.
supersuburban2005
Reg: 11-23-22
12-01-22 05:54 AM - Post#2850761
I have performed the swap from the 4l60 to a 4l80. my reasoning was I put a 400hp 6.0l in front of it. Although it runs well, it is geared really low in 1st (good for towing). It was a moderately difficult swap and I have not been able to get the stability control or traction control to work since performing the swap. I would just opt to get a 2500
Execution time: 0.107 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:19 AM
