Username Post: 2020 Silverado tire size change        (Topic#370140)
regbob
regbob
Loc: Minneapolis MN
Reg: 04-02-11
11-21-22 07:35 PM - Post#2850336
I have a 2020 High Country K1500 with the 3.0 diesel. I want to change the 275/50R 22 tires out to 275/55 R22 for better snow/water traction and hopefully a little taller side wall will give a better ride. My question is will the taller tire cause any problems with speedometer readings, issues with ABS/traction/cruise control or any other potential issues?
Matt
Member #2440
Matt
Loc: SAV
Reg: 09-26-01
11-21-22 09:29 PM - Post#2850339
    In response to regbob
That's about 1 inch difference. No big deal. Speedo will be off a couple of MPH.
Site Ambassador
11-22-22 09:55 AM - Post#2850349
    In response to Matt
Actually I come up with a little over 1/2 an inch (275 x .05) since the tire aspect ratio is 55% compared to the stock 50%. A 5% difference. That comes to 13.75 mm, which is about .54 inches. I put on tires about 1/3” taller on my truck and it made no difference.
1957 Cameo Carrier
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
11-22-22 03:11 PM - Post#2850357
I do know that some vehicles are super sensitive to the wheel speed sensors compared to the engine and transmission speeds. Depending upon the software in your vehicle systems, you might get ABS codes because the computer will see the wheels spinning slower than the computer expects to see them spin.
There are also parameters in the transmission that calculate slip and may also be an issue.
Drive it and see. If you have issues, your dealer can calibrate for larger tires.
11-24-22 10:23 AM - Post#2850433
i have never had or heard of any problems
dgstarr
dgstarr
Loc: Portland, OR
Reg: 04-16-13
11-24-22 10:44 AM - Post#2850437
If you really want a better ride, switch to the 18 inch tires and wheels that come on a LT Z71. I have had two of these trucks and have a great ride. The more rubber the better the ride.
Execution time: 0.14 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:50 AM
