Username Post: 2008 Malibu P0455 fuel smell        (Topic#370122)
mrtube
mrtube
Loc: New jersey
Reg: 08-12-03
11-18-22 11:28 AM - Post#2850192
Hello all,
I'm helping a friend with his 2008 Malibu with a 3500.
Codes : P0455
Symptoms : Check engine light. Stinks of gas after filling up for a day or so but then that fades.
I replaced the vapor purge valve and cleared codes but the problem remained.
What should my next steps be? I'm guessing the canister may be cracked, or the lines going to it?
11-18-22 02:31 PM - Post#2850205
    In response to mrtube
A quick Google search for that code shows a step by step repair analysis.
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
11-21-22 01:59 PM - Post#2850324
Try using a refrigerant leak detector to trace down the fuel leak area. The detector basically alerts you to the absence of oxygen and the fuel vapors will displace oxygen.
That will give you some area to search.
11-24-22 02:07 PM - Post#2850450
does he overfill it? thats not good to do. neither is cranking the piss out of the cap when installing it. tsbs? last year i got my wife a new fuel pump that was doing something similar on a tsb recall.
Execution time: 0.103 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:08 AM
