 Page 2 of 2 <12
Username Post: 53 BEL AIR CONVERTIBLE        (Topic#369988)
J Mack
Gold Supporting Member
J Mack
Loc: Boise Idaho
Reg: 11-02-22
02-10-23 10:54 AM - Post#2854339
    In response to J Mack
Attachment: 20230210_103705.jpg (2.82 MB) 12 View(s)
Going back together now.
Attachment: 20230210_103056.jpg (2.76 MB) 10 View(s)
Starting to figure out the electronics for the shocks.
Bigassbubba
Reg: 02-11-23
02-11-23 07:03 PM - Post#2854395
Buddy, thinking about moving to I d a ho from NH to hang in u garage ????. Bobm
Bigassbubba
Reg: 02-11-23
02-11-23 07:04 PM - Post#2854396
    In response to Bigassbubba
Watching the build ????
J Mack
J Mack
Loc: Boise Idaho
Reg: 11-02-22
02-12-23 06:48 AM - Post#2854403
Good to see you Bob M
J Mack
J Mack
Loc: Boise Idaho
Reg: 11-02-22
02-23-23 08:51 AM - Post#2854894
A couple simple issues brought this entire project to a halt for a week while I surfed the web looking for solutions.
Attachment: s-l1600.jpg (241.8 KB) 10 View(s)
First the cylinder heads that came with this engine needed to be rebuilt and the quote came back from the machine shop at $2000.00 if the castings checked out OK for all new valves, springs and hardened seats. Not wanting to spend that much on those castings I set out to find some 3884520 “power pack” castings and was fortunate to find a set already rebuilt with new 1.940 intake valves, 1.5 exhaust valves, shot blasted, hot tanked & magnafluxed, hardened exhaust seat installed, guides machined with Viton valve seals for less than I could rebuild the other set.
Member #189 Moderator and "21th Year" Platinum Supporting Member
02-23-23 03:36 PM - Post#2854913
Sounds like a good score.
29-41, 42-48, 49-54 Moderator
Bigassbubba
Reg: 02-11-23
02-23-23 04:27 PM - Post#2854916
Nice.
J Mack
J Mack
Loc: Boise Idaho
Reg: 11-02-22
02-24-23 05:48 PM - Post#2854973
Little more done today..
Attachment: 20230223_171527.jpg (1.03 MB) 8 View(s)
Got the engine painted.
Attachment: 20230224_114021.jpg (2.95 MB) 8 View(s)
Now I need to figure out how to make everything fit.
Attachment: 20230224_115419.jpg (2.76 MB) 8 View(s)
This air cleaner it's going to make it tough.
Attachment: 20230224_173114.jpg (2.69 MB) 9 View(s)
Going to Cerakote black parts tomorrow..
rcr3
Site Ambassador -"19th Year" Silver Supporting Member
rcr3
Loc: MANHEIM PA. U.S.A.
Reg: 11-24-02
02-25-23 05:46 AM - Post#2854986
Like the color choice!
'67 Camaro survivor
'06 Z71 Sierra Ex Cab
'37 Chevy cp.SOLD!!6/7/14
'73 Nova pro-street project
'17 Chevy Trax LT
J Mack
J Mack
Loc: Boise Idaho
Reg: 11-02-22
02-25-23 08:18 AM - Post#2854993
    In response to rcr3
Thank you @RCR3 it is a Toyota Cavalry blue, I got a couple pint cans of sample colors and it’s what I grabbed when it was time to paint the engine. I’m trying to find an accent color I like for valve covers and air cleaner now.
I have these colors in my shopping cart now.
https://www.cerakote.com/shop/cerakote-coating /C-1...
https://www.cerakote.com/shop/cerakote-coating /C-7...
Edited by J Mack on 02-25-23 08:19 AM. Reason for edit: No reason given.
Bigassbubba
Reg: 02-11-23
02-25-23 02:13 PM - Post#2855011
Looking Awesome,just like all you builds :toast: :thumbup:
02-25-23 06:53 PM - Post#2855025
Nows the time to fabricate a removable trans crossmember. Otherwise to get it out, you have pull the engine with it, huge pita. Nice work, quite a project for sure.
J Mack
J Mack
Loc: Boise Idaho
Reg: 11-02-22
03-01-23 07:25 AM - Post#2855201
Thank you Shepherd it's nice to know I have people looking at my pictures and bringing possible issues to my attention, I'm a one man show out here doing what I can but I’m bound to overlook something.
With the X frame there really isn’t a transmission cross member as the tail shaft is right in the fork of the X so I made a mount that bolts in. I’ll try to remember to get some picture to show you to see what you think.
tommy49
tommy49
Loc: Kaleva, Michigan
Reg: 09-28-12
03-01-23 07:58 AM - Post#2855203
Just to let you know, we do look at your pictures, in awe! Your craftsmanship is superb!
Tommy
49 Deluxe Sport Coupe, 4.8/4L60E, MII, power brakes, power steering, air conditioning.
03-01-23 05:04 PM - Post#2855229
    In response to tommy49
I agree with Tommy.
03-01-23 06:09 PM - Post#2855230
Ok, but can you drop the trans out and down? that is the problem with these chassies.
Edited by Shepherd on 03-01-23 06:41 PM. Reason for edit: No reason given.
J Mack
J Mack
Loc: Boise Idaho
Reg: 11-02-22
03-02-23 08:06 AM - Post#2855239
  • Keith_Knox Said:
I agree with Tommy.
Thank you guys, most days my dog and I are the only ones looking at this junk wondering if we are making good decisions. I know when he gives me that look I need to snap a picture and see what you guys think.
Attachment: trans-mount.jpg (1.55 MB) 3 View(s)
Shepherd, this is the transmission mount and I believe the transmission will drop out the bottom. This car has a turbo 400 and everything is tight and that center section of X frame is the lowest point so I needed my mount to bolt from the top or risk grinding the bold heads off. You can see the extra ½” spacer on top that I had to add to keep my drive shaft angle correct after I finally found an oil pan that was in stock and raised the engine ½” to make it work.
Attachment: engine.jpg (1.14 MB) 5 View(s)
Getting closer on this engine, I’m making this way harder than I need to be. I decided I wanted all new hardware for the engine and they needed to be hex flange bolts and that added a week then I need needed to prep them for coating. Air cure Cerakote GRAPHITE BLACK C-102 for the stuff I didn’t want to put in the oven like the coil and distributor and heat cure Cerakote GRAPHITE BLACK H-146 for everything else. The headers and pipes are coated in Cerakote GLACIER BLACK C-7600, this coating is amazing it will withstand temperatures up to 1,800° Fahrenheit and thermal shock from those temperatures directly into water with no adverse effects, I’ve used it on everything from suppressors to turbo housings and it seems indestructible. Hoping the Cerakote for the valve covers and air cleaner gats here today
J Mack
J Mack
Loc: Boise Idaho
Reg: 11-02-22
03-04-23 06:14 PM - Post#2855338
Attachment: engine2.jpg (1.66 MB) 4 View(s)
I'm getting closer, I need to make a valley PCV Baffle then button everything up for the final time.
rcr3
rcr3
Reg: 11-24-02
03-05-23 05:06 AM - Post#2855350
'67 Camaro survivor
'17 Chevy Trax LT
J Mack
J Mack
Loc: Boise Idaho
Reg: 11-02-22
03-10-23 07:49 AM - Post#2855592
    In response to rcr3
Attachment: 20230309_134647.jpg (235.68 KB) 4 View(s)
Not a lot of photo opportunities lately just a lot of little rust repair and welding holes that won't be used, I did find a local guy to give me a hand on the body and paint work to get back in track. I hope to be driving this summer.
J Mack
J Mack
Loc: Boise Idaho
Reg: 11-02-22
03-12-23 02:20 PM - Post#2855686
Attachment: 20230312_131654.jpg (3.22 MB) 2 View(s)
Taking the transmission apart today and starting to clean and inspect the parts
Bigassbubba
Reg: 02-11-23
03-12-23 03:05 PM - Post#2855688
Love it! Color choice ????. You know what i'm talking about!
Bigassbubba
Reg: 02-11-23
03-12-23 03:07 PM - Post#2855689
Lotta work Bud! Doing Great!????????
J Mack
J Mack
Loc: Boise Idaho
Reg: 11-02-22
03-13-23 06:51 AM - Post#2855706
I'm leaning towards blue and ivory; as soon as I get this transmission back together I should be done with the major mechanical work and I can start focusing on undercoating the underside of the body and getting it painted body color.
J Mack
J Mack
Loc: Boise Idaho
Reg: 11-02-22
03-17-23 08:32 AM - Post#2855877
Made a little more headway yesterday.
Attachment: 20230317_092348.jpg (2.95 MB) 1 View(s)
I got the engine and transmission sitting in the frame rails hopefully for the last time.
Attachment: 20230317_091003.jpg (4.12 MB) 1 View(s)
Starting to try to figure out a throttle pedal that isn't too much bling.
Attachment: 20230316_171302.jpg (3.01 MB) 0 View(s)
Joining a factory style pedal with a summit racing billet pedal
 Page 2 of 2 <12
Execution time: 0.094 seconds.   Total Queries: 25   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:21 AM
