Username Post: cyl head temp        (Topic#369980)
Airlifter
Airlifter
Reg: 06-07-15
11-05-22 05:37 AM - Post#2849645
I am real close to closing the deal on a '65 corsair.
I have read that cyl head temp should run normally between 400 and 500 degrees. What would cause the temp to go beyond this range? The first thing that comes to mind would be timing. What else would cause this?
Thanks in advance, Pete
1951 styline deluxe sport coupe w/'60 261 engine & 54 powerglide
1965 Corvair Corsa 140 hp 4 speed convertible
Mel Foye
Mel Foye
Reg: 09-29-00
11-06-22 06:48 AM - Post#2849705
    In response to Airlifter
Fan not moving enough air.
It Was On Fire When I Laid Down.
docjns1
docjns1
Loc: upstate NY
Reg: 11-12-19
12-16-22 03:09 PM - Post#2851349
    In response to Mel Foye
If I recall, along with the belt driven fan those flat 6's had lower air ducts below the heads/exh manifolds with thermostatic flapper doors at the rear. The flappers were operated with bi-metal coils or springs similar to an old choke coil and opened or closed to let air pass, thereby aiding in warm up and cooling. Be good to know they're operational (assuming they're still in place) as well as muffler shields between mufflers & valve covers
Attachment: vair_ducts.jpg (6.87 KB) 10 View(s)
Steve
327 / 300 L74
M11 3 on the tree
12 bolt 3.31 open dif
Execution time: 0.139 seconds.   Total Queries: 20   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:26 PM
