Username Post: How much amps can a 1941 Chevy ammeter handle?        (Topic#369976)
FishFry
FishFry
Loc: Augsburg - Germany
Reg: 11-01-22
11-04-22 07:48 AM - Post#2849598
I'm just doing all new wiring, and just realized that pretty much everything is going straight trough the ammeter. I converted to 12V and running a standard GM 10si 3 wire alternator (I think it delivers up to 65 amps), so I was also planning to use a bigger gauge alternator cable to the battery/starter post, also the remote sensing cable should go there.
The question is now, does it make any sense?
Having the remote sensing cable at the starter (which is also basically my hub for everything) and compensating for the voltage drop, the alternator will output more power. But will the ammeter handle that?
Thanks, Frank
Mel Foye
Mel Foye
Reg: 09-29-00
11-06-22 07:45 AM - Post#2849708
    In response to FishFry
Are there numbers on the meter that show a range?
It Was On Fire When I Laid Down.
FishFry
FishFry
Reg: 11-01-22
11-06-22 12:29 PM - Post#2849726
    In response to Mel Foye
Just C and D and a few dots between.
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
11-08-22 12:56 PM - Post#2849801
What size conductor was in there before converting to 12V?
Greg
‘01 Silverado 2500HD 8.1/Allison 1000 Xcab/LB
'00 Explorer XLT 4.0 SOHC V6 Auto
'95 K1500 Z71 EC Short Step 5.7L+0.040/NV3500 SOLD
FishFry
FishFry
Reg: 11-01-22
11-08-22 11:39 PM - Post#2849823
    In response to CowboyTrukr
I rewired the whole car about 15 years ago - since it was 6V, I used AWG 10 for pretty much everything.
2 years later I swapped the generator for a 3 wire alternator (6V) that came with it's own wires. Not 100% sure but I guess the cable to the ammeter is also a 12.
Now I have a AWG 8 that I want to use for the alternator.
Frank
11-13-22 09:33 AM - Post#2850023
i wire ampmeter so only battery charge shows. everthing else is taken from the alternator side of the meter. not saying its right. its the way i like it.
11-13-22 10:56 AM - Post#2850031
    In response to bobb
Just say'n here, if it were me I'd dump that ammeter and switch to a voltmeter, safer system than a possibly overloaded ammeter.
FishFry
FishFry
Reg: 11-01-22
11-13-22 12:04 PM - Post#2850033
    In response to bobb
Interesting. Could you please post a drawing or diagram, so I get a better grasp?
Thanks, Frank
11-19-22 09:19 AM - Post#2850226
battery to starter + wire, big and strong.
alternator + to buss bar that feeds everything else fused or fuse linked including feed through amp gauge to battery. from buss bar to amp gauge and bat i like at least 10 gauge for a short run. bigger for longer runs. hope this make sense.
11-19-22 11:13 AM - Post#2850235
    In response to bobb
Good info, but as I said, what happens if the ammeter is overloaded, I've seem them show signs of beginning to burn in cars with additional loads and more amperage available and increased charging rates.
11-20-22 10:41 AM - Post#2850269
that is why the only amps going through my gauge is battery charging amps. not system load amps. true these things can fry and have always considered that but thats a chance i take for now. there may be inductive gauges available that are fire safe.
11-20-22 12:53 PM - Post#2850288
    In response to bobb
Safer way to to connect it.
FishFry
FishFry
Reg: 11-01-22
11-21-22 01:47 AM - Post#2850305
    In response to bobb
So basically something like this?
11-24-22 01:18 PM - Post#2850446
https://www.fwmurphy.com/uploaded/documents/pd fs/0...
this drawing is a bit simplified as it does not include a fuse box or buss bar. it just notes, to electrical system.
discussions like this are good to ponder. in the event of alternator failure, all current draw will flow through the amp gauge.
Edited by bobb on 11-24-22 01:38 PM. Reason for edit: No reason given.
FishFry
FishFry
Reg: 11-01-22
11-24-22 10:28 PM - Post#2850465
    In response to bobb
Thanks Bob.
I'm basically using my starter as a bus bar, but would the drawing I posted earlier be correct regarding the "splicing in" of the ammeter?
Frank
11-25-22 08:54 AM - Post#2850481
looks like that drawing bypasses the gauge giving you a 0 reading.
FishFry
FishFry
Reg: 11-01-22
11-25-22 10:21 AM - Post#2850490
    In response to bobb
I don't get it. Isn't that exactly how you described it?
"battery to starter + wire, big and strong.
alternator + to buss bar that feeds everything .. feed through amp gauge to battery".
Obviously I'm too stupid.
Can you please make me a drawing.
Nothing fancy - pan and paper are fine.
Thanks, Frank
11-27-22 10:27 AM - Post#2850586
if you use the battery as a buss, all amps are running through the amp gauge. i use the alternator big wire for the buss. but not at the alternator. very similar to this.
https://www.tractorforum.com/attachments/12v-conve ...
Execution time: 0.194 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:20 AM
