Username Post: Question about doors        (Topic#369908)
fasfred
Reg: 10-29-22
10-30-22 11:27 AM - Post#2849275
Hello Family,
I'm new to the site so if i make so mistakes please forgive me.
I have a 1956 Chevy truck 1/2 ton (3100) I have a question about the doors on a 55/56/57, I'm looking to buy a drivers side door, what i need to know is where the upper door hinge is bolted to the door is it the same on all years.
I seen a door where the hinge slides into a channel where the hinge isn't exposed, then I seen another door where the hinge bolt right to the door and the hinge is exposed.
Can anyone help me with this question ?
Edited by Tony on 10-30-22 01:04 PM. Reason for edit: Moved to more appropriate forum
monty56
"18th Year" Gold Supporting Member
monty56
Reg: 04-26-04
10-30-22 02:23 PM - Post#2849282
    In response to fasfred
As far as I know all doors from '55-'59 should be the same. one hinge slides in a channel the other is outside.
Monty
2001 Chevy Suburban 2500
2009 Saturn Vue w/20's
Monty's 56 Truck
Avatar is my Truck
Mike Boteler
Loc: Maryland
Reg: 09-11-17
10-31-22 10:00 AM - Post#2849323
Both the top and bottom hinge slide into a slot on the door. The door side hinge bolts are accessible via the small access panel at the bottom and the large panel at the top.
Mike B
Execution time: 0.079 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:22 PM
