Username Post: heater core        (Topic#369776)
apix17
Loc: San Francisco Area
Reg: 12-22-07
10-14-22 03:58 PM - Post#2848557
My 2000 blazer heater core leaks I know it is difficult to replace. Has anyone had any success with stop leak type chemicals? Thanks in advance for your input
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
10-14-22 04:58 PM - Post#2848559
    In response to apix17
Although tempting, stop leak has too many side effects including clogging the cooling system.
The only real solution is to bite the bullet and change the heater core. While I was there, I'd change the evaporator core too.
apix17
Reg: 12-22-07
10-14-22 05:40 PM - Post#2848560
    In response to Tony1963
Yes tony that is my concern also I was thinking of isolating the heater core from the rest of the system filling it with a premixed solution of hot water and stop leak. Let it sit over night then flush it. Then hook it up to the system that way the stop leak is isolated to the heater core. I might give it a try, but yes I agree the prudent way would be to change the core.
SleeperSS
Loc: Spanaway, Wa
Reg: 10-17-04
10-15-22 09:59 PM - Post#2848620
It sounds like a big job, but removing the dash is the best approach. As for the evaporator core, unless your ac isn't working there's no need and a waste of time.
U.S.C.G. "So others may live"
'96 S-10 SS
2021 Blazer Premier
10-18-22 02:57 AM - Post#2848726
    In response to SleeperSS
Agreed! When my '96 Jimmy core leaked, we took out the dash. Cleaned out all duct work too.
'08 GMC Acadia 3.6L SLE
gcrkfrd
"6th Year" Platinum Supporting Member
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
10-25-22 07:38 AM - Post#2849029
I used some stuff, in a blue bottle, it was about $35. Don't remember the name, but it did the impossible job, of sealing a North Star Caddy. Drove the car 6,000 miles then sold it. Told the people it had stop leak in it, and they are still driving it. another thing to check, on GM heater cores, look to see if it has the plastic adapters, from the core to the hoses. I have had two later GMs with cracked adapters.
1952 Styleline Sedan, 62-235, Drum brakes, Manual steering, 2" Drop, 8-60 AC, Glass packs, Two Carbs, and a Cast Iron PowerGlide-
Way out behind the Old School
Half a Dozen in a Row, all it needs for Her to go.
Execution time: 0.099 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:12 AM
