Username Post: My 1964 chevy impala has no power        (Topic#369764)
Allchromed62
Reg: 10-12-22
10-13-22 05:51 AM - Post#2848475
I have a 1964 Chevy impala Tudor hard top with A327 motor in it. I recently recently changed it over to to hei with one wire hook up to the alternator. I don't have the distributor in it yet. I wanted to set the timing but I have no power to anything. I have the engine grounded to the frame and frame to the body. I replaced the steering column with a billet one. No key in the column. Has both new engine and front light narness on it. Were should I start looking first for troubleshooting??? Please help
Edited by Tony on 10-13-22 11:13 AM. Reason for edit: Moved to correct forum
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
10-13-22 03:24 PM - Post#2848506
    In response to Allchromed62
Check the main harness connection at the firewall, under the brake master cylinder. That is a known wear point and the contacts in the plastic connectors get loose.
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
10-14-22 06:37 AM - Post#2848530
    In response to Tony1963
Might have something to do with that one wire alternator. Check with the manufacturer. Is the engine harness to one for the one wire, or rewired correctly?
327
Loc: Ontario , Canada
Reg: 02-09-21
10-14-22 06:25 PM - Post#2848564
LIKE YOU WOULD KNOW !!!
Execution time: 0.148 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:45 PM
