Username Post: gas smell        (Topic#369551)
Airlifter
Airlifter
Reg: 06-07-15
09-22-22 04:40 AM - Post#2847654
I have a Carter YF 2101 carburetor on my 261 engine and I am getting the smell of gas. I have noticed this more on really warm days. I have checked for leaks. I have looked at the carburetor with the engine running and immediately after turning the car off. I have lowered the float to cure a flooding problem. The car runs great otherwise.
What else should I be looking at?
All help appreciated, Pete
1951 styline deluxe sport coupe w/'60 261 engine & 54 powerglide
eplantage
Loc: Southern MN
Reg: 03-15-04
09-22-22 11:11 AM - Post#2847669
    In response to Airlifter
I would look over the entire fuel system underneath your car to make sure you don't have a leak there. Including the top of the tank where the sending unit is.
Age: 67 at the moment
1950 Chevrolet Sedan Delivery
2002 Heritage Springer FLSTSI
1930 Model A Standard Coupe
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
09-22-22 03:39 PM - Post#2847674
This is not a closed system and today's volatile fuel is designed for a closed system.
Check for leaks, but do not overlook the fact that the carburetor vents to the atmosphere and that's probably where the vapors are coming from.
09-22-22 08:42 PM - Post#2847680
    In response to Tony1963
A Carter YF 2101 doesn't vent to the atmosphere unless you count the open throat that the air cleaner slips over.
Tony1963
Reg: 07-09-18
09-22-22 10:47 PM - Post#2847682
Yes, that is exactly what I mean.
09-23-22 04:45 AM - Post#2847684
To add, the vented gas tank cap.
Airlifter
Airlifter
Reg: 06-07-15
09-23-22 05:20 AM - Post#2847687
Thanks for the responses. So, is there anything I can do about the smell?
09-23-22 08:35 AM - Post#2847692
If no obvious leaks, venting the area is all you can really do. Make sure that any connections to the filler and tank are not wet or leaking.
Airlifter
Airlifter
Reg: 06-07-15
09-23-22 01:46 PM - Post#2847708
Tony1963
Reg: 07-09-18
09-23-22 04:44 PM - Post#2847714
Several years ago, I had a 1980 Chevrolet Monza coupe and it had the 4-cylinder and otherwise well equipped. When I parked the car in the garage after driving, we had to deal with gasoline smell as well.
The solution was to leave the car outside until the engine cooled down, then park it in the garage.
The volatile gasoline of today is different than the gasoline of yesteryear.
Execution time: 0.089 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:58 AM
