Username Post: front shock mounting        (Topic#369525)
larryreyer
Reg: 06-01-20
09-19-22 02:30 AM - Post#2847511
59 Bel Air, front shocks are Monroe 5765. They didn"t come with a upper set of bushings or even room for 2 bushings, I can't load a picture but if you look up Monroe 5765 you will see what i mean
Seon
Loc: Lake Camanche, CA
Reg: 07-14-02
09-19-22 04:06 AM - Post#2847512
    In response to larryreyer
Wow, I just bought a Monroe set from Amazon but hadn't open the box yet. I checked Amazon's
picture on line that didn't show the top bushing and washer. I see that Amazon sells a pair of those for $5. I'll check NAPA auto if they sell the bushing and washer.
Seon
Reg: 07-14-02
09-20-22 07:25 AM - Post#2847565
    In response to Seon
I just opened the boxes and check the shocks and that they appear they are designed of not using bushings. Boxes contained shocks, lock washers and nuts.
gcrkfrd
"6th Year" Platinum Supporting Member
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
09-20-22 08:51 AM - Post#2847566
    In response to Seon
I just bought a new set of Monroes, and One had a Fine threaded stud and nut on the top, and bottom, and the other had a coarse threaded stud and nut on top, and bottom. They both came with washers and rubbers.
1952 Styleline Sedan, 62-235, Drum brakes, Manual steering, 2" Drop, 8-60 AC, Glass packs, Two Carbs, and a Cast Iron PowerGlide-
Way out behind the Old School
Half a Dozen in a Row, all it needs for Her to go.
larryreyer
Reg: 06-01-20
09-20-22 09:36 AM - Post#2847571
    In response to gcrkfrd
I finally made rubber pads for mine. In the box of spare bushings, I found a found another one with the matching raised area to go in the hole in the frame, actually the old one off the old shock was same. put it in a vice, and cut it in half, making it thin enough to still put a washer and nut on it. I don't like metal to metal, plus there is nothing to keep it centered in the frame hole.
Edited by larryreyer on 09-20-22 09:37 AM. Reason for edit: No reason given.
larryreyer
Reg: 06-01-20
09-20-22 09:42 AM - Post#2847572
I found a soft foam bushing to put under the frame, put that on shock first...................no offence, but I think gcrkfrd has a different model shock
Execution time: 0.089 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:42 AM
