Username Post: Painting a Corvette        (Topic#369477)
sting199
Reg: 12-12-19
09-12-22 06:16 PM - Post#2847251
Aprox, how much paint will I need to paint a 79 Corvette? (primer, basecoat and clearcoat?) Thanks!!!
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
09-14-22 12:40 AM - Post#2847292
    In response to sting199
About two quarts of each.
09-14-22 07:34 AM - Post#2847303
depends how thick you want the paint. 2qts is paper thin. when i was painting cars it would take about 1 gallon of paint for 3 coats. clear would normaly be less if you dont sand it and buff it.
Tony1963
Reg: 07-09-18
09-14-22 12:03 PM - Post#2847313
    In response to bobb
If he is using base coat, then the color needs to be sprayed until even. The clear coat is where the real gloss lies.
Keep in mind that on a Corvette you have less surface area than a sedan. I found the two quarts did a nice job. Two quarts of paint equates to about four quarts of spray when reduced.
Two quarts of clear is about 2.5 quarts when the activator is added. Enough for 3 coats of clear.
Mel Foye
Mel Foye
Reg: 09-29-00
09-20-22 05:54 PM - Post#2847602
    In response to Tony1963
To me Tony 1963 with looking for a real flat surface most of the first layers of primer get sanded off. Still just to qts of primer? Mel
It Was On Fire When I Laid Down.
Edited by Mel Foye on 09-20-22 05:54 PM. Reason for edit: No reason given.
Tony1963
Reg: 07-09-18
09-21-22 02:20 PM - Post#2847639
    In response to Mel Foye
It depends upon if we are measuring materials to complete bodywork or prep to paint. Once you have the surface finished, that is what I am referring to.
sting199
Reg: 12-12-19
10-02-22 02:45 PM - Post#2848042
    In response to bobb
thanks!!!
sting199
Reg: 12-12-19
10-02-22 02:47 PM - Post#2848043
Thanks for your help!!!!!
Execution time: 0.13 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:17 PM
