Username Post: HELP: Neutral Safety Switch on 69        (Topic#369210)
vabeach56wagon
Loc: Chesapeake,VA,
Reg: 04-22-02
08-16-22 11:13 AM - Post#2845994
Is the feed off the neutral safety switch continuous, once past the two-prong connection, all the way to the solenoid? When the solenoid would no longer engage, I thought the relatively new neutral safety switch had gone bad. I bypassed the neutral switch by bridging the ignition switch feed to the existing solenoid feed...alas, still no activation at the solenoid.
I then installed a jumper wire from the solenoid to the outlet side of the neutral switch and, voila, the solenoid powered up off the ignition switch and I was able to start the car.
In my wiring diagram I see no junction on the purple feed to the solenoid other than the one directly above the pedal assembly. Is there one further downstream I should look for. I'm trying to avoid tearing into the harness.
paul
Original builder of the Gobstomper - '56 210 9 passenger wagon now in other's hands. Current Ride is '69 X33D80 Z28 Camaro
Execution time: 0.084 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:29 AM
