Site Ambassador
10-10-22 07:33 PM - Post#2848369
In response to Jonechev
Have you checked the door check strap? In case you don’t know, it’s the bar that bolts to the door jamb that limits how far the door will open. They often don’t get lubricated regularly and develop a squeak. The easiest thing to do is lubricate it and open and close the door repeatedly to distribute the lube. If you want to make certain that is what it is before you lube it you can unbolt it from the pillar, retract it, then swing the door towards the closed position and see if it makes the noise. It can be hard to pull it back out to bolt it back up though.
1957 Cameo Carrier |
