Username Post: What A Disappointment        (Topic#369174)
41wildthing
41wildthing
Loc: NJ
Reg: 12-02-15
08-10-22 03:26 PM - Post#2845727
A while back I talked about a good running 235 ci motor that I was able to acquire for free. My plans were to remove the 216 in my 1941 Special Deluxe and swap in the 235. BTW it was a 1958 model full pressure motor. My problem is, and I never knew of this prior, I was told after the 216 was removed, that the new motor would not fit my car since it has a Mustang II front axle. Bottom line has anyone heard of the problem of is someone blowing smoke up my rear? Thanks in advance....Phil
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
08-10-22 04:41 PM - Post#2845729
    In response to 41wildthing
This is likely due to the engine mounts would be on the front apron on the Mustang II and not the front subframe?
https://ls1tech.com/forums/conversions-sw aps/18062...
Member #189 Moderator and "20th Year" Platinum Supporting Member
08-10-22 08:52 PM - Post#2845738
The 235 will fit where the 216 was. The 216 uses a front mount off of the front cover. You can drill the 235 front cover for the mount. Do not know why they would say it won't fit. You would nee to use the flywheel from the 216 as it is 6 volt. The water pump may have to be lowered and there is a plate to do that. Good luck.
29-41, 42-48, 49-54 Moderator
1971BB427
Loc: Portland,Or
Reg: 12-06-09
08-12-22 07:55 AM - Post#2845793
I have a friend with a 1940 sedan delivery that's been retrofitted with a 235 from 1954. I just saw his car for the first time on Wed. so have to ask him what he did, or if it was already done and maybe look at it to see how it was fitted into his '40?
1969 Suburban 2wd 350
1939 Chevy pass. coupe 350/700R4
1937 Austin gasser 327/TH350
41wildthing
41wildthing
Loc: NJ
Reg: 12-02-15
08-14-22 04:02 AM - Post#2845893
    In response to 1971BB427
Thanks Vall I appreciate anything you can impart to me. BTW did you ever find an appropriate suicide knob that was to your liking for your 1939 coupe? If you did. I'd like to see a pic if you can. Thanks.....Phil
1971BB427
Loc: Portland,Or
Reg: 12-06-09
08-17-22 08:29 AM - Post#2846028
Not yet Phil, but honestly haven't been looking really hard. I keep forgetting to ask a friend who does garage and estate sales, and specializes in old car items if he might have one.
JAS40
Loc: Upstate NY Catskills
Reg: 12-19-21
09-09-22 05:10 AM - Post#2847055
https://davisspeedequipme nt.com/product/10082-fron...
1971BB427
Loc: Portland,Or
Reg: 12-06-09
09-09-22 06:46 AM - Post#2847062
Update-It seems everything in the way of modern spinner knobs is for modern fat steering wheels! I got a simulated wood knob off Amazon, but it's much larger than my '52 Chev wheel, and using rubber to build up the difference didn't work well. It got tight, but when I turn with it the rubber gives and wants to let the knob flex.
My friend's sedan delivery was already converted to a 235 when he bought it, so he's unsure what was done. From what I could see looking it over, it appears it bolted right up to the 216 bellhousing, and mounts look factory too?
Edited by 1971BB427 on 09-09-22 06:48 AM. Reason for edit: No reason given.
41wildthing
41wildthing
Loc: NJ
Reg: 12-02-15
09-11-22 11:35 AM - Post#2847157
Thanks Vall. I appreciate you finding the information for me.....Phil
sidworks
Loc: Saturna Island, B.C.
Reg: 12-03-05
09-19-22 08:27 PM - Post#2847556
did you have the mustang II front in there with the 216 installed or was it put in after you took the 216 out. the mustang II would more than likely remove the orig. front mounting of the engine framewise and i don't know if there is a facility to put that front mount in. 58 engine has provision for side mounting so that may be the way to go.
ron
41wildthing
41wildthing
Loc: NJ
Reg: 12-02-15
09-21-22 06:36 PM - Post#2847648
    In response to sidworks
Sorry it took so long to respond to you, but the answer to your question is, the M II front axle was in the car with the 216 already in place and working fine. I think the problem was the individual I hired to do the swap didn't want to take the extra time to do it properly or he was in over his head and was looking for a way out. I decided to just trash the whole idea and keep the 216 unfortunately. It cost me a bunch of money which I wasn't happy about. Thanks....Phil
Execution time: 0.098 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:11 AM
