Username Post: 28 coupe engine removal        (Topic#369171)
grumpy
Reg: 08-10-22
08-10-22 06:08 AM - Post#2845692
I am a new member and need help removing the engine. I have read in the manual that I need to split the u-joint and I am not clear on this. my objective is to replace the clutch. I have been restoring WW2 military vehicle for the past 20 years or so and this is my first venture into a 28 chevy. Any advise will be welcome, critical pictures would help a lot. I thank you in advance for any help.
grumpyvette
grumpyvette
Loc: farmersville texas USA
Reg: 03-16-01
08-29-22 12:16 PM - Post#2846491
    In response to grumpy
https://www.harborfreight.com/ball-joint-service-k...
https://www.harborfreight.com/12-ton-shop-press-33...
it helps to have the correct tools a hydraulic press, and or tools designed to remove u-joints
don't beat them with a hammer it almost always results in damage, use a tool or press
https://www.youtube.com/watch?v=5gOeBE-ylQw
https://www.youtube.com/watch?v=uewFHe6H2Tw
https://www.youtube.com/watch?v=rOEdul7nscY
Edited by grumpyvette on 08-29-22 12:19 PM. Reason for edit: No reason given.
Execution time: 0.138 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:31 PM
