Username Post: 1963 Impala Powerglide Speedometer Drive Gear ?        (Topic#369139)
Rakman
Loc: Southwest PA
Reg: 11-02-18
08-05-22 06:01 AM - Post#2845487
Just had the 283 with the PG replaced with a crate 350 and a TH350 tranny. Noticed on the highway the my GPS is telling me I'm doing 60MPH, and my speedometer is telling me I'm doing 75mph.
I asked the guy who replace the tranny if he knew which Speedometer Drive Gear was on the TH350. He told me he just moved the Drive Gear from the PG to the TH350 but didn't notice how many teeth were on the gear.
Does anyone know which Speedometer Drive Gear would of been on the PG from the factory?
Obviously, I hoping to just replace the Driven Gear to get the speedometer closer to my actual speed.
Thanks in advance to anybody who may be able to answer my question. This forum has been a great resource through-out my restoration process.
-Rakmann
junky
Loc: Northeast CT
Reg: 06-27-10
08-05-22 06:22 AM - Post#2845488
    In response to Rakman
I made a post about how to determine the correct gear in a post a few years ago. Should have all the information that you will need.
55Brodie
Loc: Little River, SC
Reg: 12-26-15
08-05-22 07:23 AM - Post#2845493
Your speedometer is reading 25% fast which means the driven speedometer gear will need 25% more teeth for correction. I think this will be impossible. I would try the TH350 gear and compare with the GPS and do the math again.
dgstarr
dgstarr
Loc: Portland, OR
Reg: 04-16-13
08-05-22 12:59 PM - Post#2845506
!963 pass with 3.08 or 3.36 axle: 8 teeth (1 27/32 OD X 39/64 thick) 3708144. This info name from GM parts manual.
docjns1
docjns1
Loc: upstate NY
Reg: 11-12-19
08-05-22 01:14 PM - Post#2845507
    In response to dgstarr
1st thing coming to my mind is this...if final trans drive is straight out 1:1 (no o.d.), and the 'glide drive gear was used in the 350, and assuming you used the same driven gear that was in the car, there should be no change in the speedo.
350 drive gears were typically only a 7 or 8 tooth gear, most change was with the driven gear and/or use of an adapter where necessary. Junky's link to the previous thread is a good reference. I've attached a chart with some #s for you as well. As for the driven gear, 1 tooth would result in a 3-4 mph change on the speedo. You'd need to add 4 ( maybe 5) teeth to the driven gear to accomplish this so it 's all dependent on # of teeth you currently have
Steve
327 / 300 L74
M11 3 on the tree
12 bolt 3.31 open dif
docjns1
docjns1
Loc: upstate NY
Reg: 11-12-19
08-05-22 01:34 PM - Post#2845509
    In response to docjns1
If you're changing the driven gear you're lucky in that the 1 27/32 drive gear equates to 1.84" in the chart I've provided. Since its a bit larger, the driven gears are just a bit smaller (see attached photo) to properly mesh. The 'smaller' gears are more readily available and easily identified as the last 2 digits of the part# is the # of teeth
Attachment: speedo_gears.jpg (1.77 MB) 1 View(s)
Steve
327 / 300 L74
M11 3 on the tree
junky
Loc: Northeast CT
Reg: 06-27-10
08-05-22 04:23 PM - Post#2845519
To use the larger gear on the left, you have to change the gear in the tail shaft. If you don't, then the plastic gear will get chewed up in 100 miles. I know, because that is what happened to one of my other cars.
docjns1
docjns1
Loc: upstate NY
Reg: 11-12-19
08-06-22 09:53 AM - Post#2845536
    In response to junky
thats correct, I had the opposite problem, smaller gear on output/main shaft requiring larger driven gear.
Online seller substituted the smaller one that hardly meshed as it was same # teeth then proceeded to argue about it...not worth the few $$ it cost, Speedo read about 30 and jumped around when I was actually doing about 50
Steve
327 / 300 L74
M11 3 on the tree
Rakman
Loc: Southwest PA
Reg: 11-02-18
08-07-22 06:52 AM - Post#2845569
Gentelmen...I can't thank you enough for your information.
-Rakmann
Execution time: 0.101 seconds.   Total Queries: 19   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:49 AM
